Dex-cool
motownguy
PostPosted: Wed Sep 05, 2007 12:45 pm    Post subject: Dex-cool Reply with quote
Hi,
I had my 2001 Grand Jeep Cherokee in for a radiator flush & fill. I noticed that they used a red colored antifeeze. I think it's called Dex-cool? I have heard from other people that if the vehicle does not come with Dex-cool as origanal antifreeze don't use it, and I'm sure that mine did not. They also say that you can use it "only" if you do a complete flush, which I'm sure they did not do, even though I requested it. I called the dealership and asked about it and they told me my Jeep calls for it, what do you think?
Thank you.
PostPosted: Wed Sep 05, 2007 6:31 pm    Post subject: Reply with quote
I have no Idea... I use cheap crap in mine.. rofl rofl
PostPosted: Wed Sep 05, 2007 8:52 pm    Post subject: Reply with quote
its ether extended life coolant (propylene glycol) or its just normal coolant (ethylene glycol) with more or different additives .
the coolant in my jeep is purple , its just normal coolant . the coolant in my dads truck is green and its completely different from the green stuff you normally buy . i just put in red coolant into my sisters car , didn't call for it . doesn't matter .
my guess is that it is ethylene glycol (normal) with more additives to help cool the engine better like volvo VCS coolant .
or its extended life .
all i can say is only put in that coolant if you have to top up or you could end up with a block full of jello .
PostPosted: Wed Sep 05, 2007 8:57 pm    Post subject: Reply with quote
did a google search .
its ethylene glycol
* Lower alkalinity
* Contains NO silicates, resulting in longer lasting water pump and engine seals; longer shelf life.
* It is Nitrite-, borate-, phosphate-, nitrate- and amine-free.
* 100% biodegradable in its pure unused condition.
* Longer lasting (Dex-Cool has been shown to remain above 95% of its original concentration after 150,000 miles in automobiles)
the only problem i see is no silicates because the silicates swell your seals and keeps it from leaking so if it leaks all of a sudden its because the coolant doesn't swell the seals . on the other hand there is no silica to build up on the block and keep it from cooling properly , if i remember 1/4" of scale is = to 3 inches of plate .
so it has its goods and bads , if it doesn't leak for you then your all good .
also it seems its a GM coolant . strange they want it in a jeep .
drakan1908
PostPosted: Sat Sep 08, 2007 11:28 am    Post subject: Reply with quote
wifes 97 malibu came with dex-cool,now i just use advance auto brand and it says it will mix and work with any other brand. been using it for about 5 years so far no problems
