Broken sway bar
jp4whln12
PostPosted: Sun Sep 09, 2007 11:39 am    Post subject: Broken sway bar Reply with quote
Well after some off roading i noticed my left sway bar on the front end was disconnected from the top. It looks like it pulled right out. I tried jacking it up and aligning it back up hoping it would just pop back in place but it is apparent that something is broken as it still pops. I'm not sure how to explain how it is disconnected but the result is just a cup(?) at the end of the link.
I need to know is there any way of fixing this or should i buy a new one? And then that brings up the question of going for the factor replacement or buying some JKS quicker discos. I'm looking to get a BB and 1" body lift soon so would the 0" to 2" lift version work for the lift down the line?
blktrax
PostPosted: Sun Sep 09, 2007 12:30 pm    Post subject: Reply with quote
You didn't break the bar you broke the endlink. 30 bucks or so
boby lift has no bearing in this part. only a suspension lift and i used a 2" budget boost with a 1 in body just fine with the jks -2 in discos
jp4whln12
PostPosted: Sun Sep 09, 2007 2:53 pm    Post subject: . Reply with quote
Oh ok thanks. Does this happen often?
I think im going to just order myself some JKS quicker discos, seems they are more reliable. In the mean time should i worry about driving with it like this? I've been taking the cornors slower lately and i haven't noticed and more wobble then before
