Quesions about rim/tire fitment
doctorres112
PostPosted: Thu Sep 13, 2007 8:53 pm    Post subject: Quesions about rim/tire fitment Reply with quote
Okay so I'm not sure if this belongs in the rim category or the cherokee category but since I drive a cherokee I will put this here.
I was wondering if a set of Jeep Rubicon rims (16 in.) along with tires (245/75R16) would fit on a stock 2001 Cherokee Sport. I am in Afghanistan right now so I cannot check myself. I figured I would call the jeep dealership as well but since it's 1 a.m. in the states right now I might as well post it here also.. Thanks.
PostPosted: Fri Sep 14, 2007 4:55 am    Post subject: Reply with quote
They should fit....but you might have some rubbing on the LCA's at full steering lock.
doctorres112
PostPosted: Fri Sep 14, 2007 7:18 am    Post subject: Reply with quote
to prevent that would I need a small lift?
PostPosted: Fri Sep 14, 2007 10:07 am    Post subject: Reply with quote
They will fit if they are from an 06 or earlier TJ (5 on 4.5"). The new JK wrangler has 5 on 5" bolt pattern. To prevent rubbing you'd either need to shim the steering stops with washers or get some spacers. A lift would do nothing unless it had skinnier control arms. You'll probably experience very little rubbing if any.
doctorres112
PostPosted: Fri Sep 14, 2007 3:27 pm    Post subject: Reply with quote
Thanks for your replies on this issue, my wife really wants these rims and tires on her XJ butshe wasn't to keen in lifting it.
