painting flares
Post new topic   Reply to topic     Forum Index -> Body & Paint
el_dubya
PostPosted: Wed Sep 19, 2007 9:59 am    Post subject: painting flares Reply with quote
I painted my flares this past spring, they looked pretty good, until it started flaking off. I used the krylon fusion, on the can it says to clean surface with ammonia and water, so I did. Aparently that didnt take all the wax and oils off. So:
1: Any suggestions on getting the old paint off? Sand it lightly, making sure not to get into the flare? And ideas?
2: What do I clean the flares with? I heard prep all from walmart works well but I cant seem to find it at any of the local walmarts. Any other suggestions that wont eat my flares away?
Anybody know what the flares are made of so I can look on cleaners to see if it is safe?
I'm hoping to get this fixed this weekend. Thanks.
Dub
'98 TJ SE
Taurus Fan
Uniden PC68 Elite CB
PostPosted: Tue Oct 23, 2007 7:33 pm    Post subject: Reply with quote
i would sand it off a bit . or try some dot 3 or dot 4 brake fluid and rub it off . just don't get it on the car .
the best paint prep is personally Dupont wash and wipe .
if you are using a spray gun mix some flex agent into the paint and perhaps prime it this time . Very Happy
TJ Apex
PostPosted: Sun May 31, 2009 2:38 pm    Post subject: Reply with quote
I am trying some spray-on bed liner stuff I got at Auto Zone. The bed liner spray goes on thick, coating only a couple passes. I tried to spray it without sanding, but it peeled off in one rubbery sheet, I tried to peel it after sanding and re-spraying and now it's not coming off. The spray doesn't have the rough texture that the roll on stuff does, it's also easer to clean too.
As far as prep, I took some 400 grit sand paper then wiped it with brake cleaner, I used brake cleaner because it dries quickly and leaves no residue.
2002 Wrangler Apex
02' Apex Edition,
2" BB, 31" BFG AT's
mivpl
Banned
PostPosted: Mon Jun 01, 2009 5:39 pm    Post subject: Reply with quote
i would sand it off a bit . or try some dot 3 or dot 4 brake fluid and rub it off . just don't get it on the car . but it peeled off in one rubbery sheet, I tried to peel it after sanding and re-spraying and now it's not coming off. The spray doesn't have the rough texture that the roll on stuff does, it's also easer to clean too.
As far as prep.
TJ Apex
PostPosted: Tue Jun 02, 2009 12:40 am    Post subject: Reply with quote
As far as prep.
WTF Finger
2002 Wrangler Apex
02' Apex Edition,
2" BB, 31" BFG AT's
Post new topic   Reply to topic     Forum Index -> Body & Paint All times are GMT - 8 Hours
