'90 Cherokee Laredo Charging System Problems
Alucard726
PostPosted: Tue Sep 25, 2007 12:24 pm    Post subject: '90 Cherokee Laredo Charging System Problems Reply with quote
Okay, my 90 Cherokee Laredo has been a faithfull strong running truck with 174k miles on it for two years now, recently its alternator went bad, after having it checked ive replaced it twice now and the battery once, the alternator puts out around 12 on the gauge rather than its original 14 and will run the truck/acc but with a noticeable strain, ive checked my wiring from the alternator and whatever fuselink ive foun around it and the motorcraft solenoid all good, but it wont charge the battery a bit. Any ideas would be much appreciated.
PostPosted: Tue Sep 25, 2007 9:00 pm    Post subject: Reply with quote
if the alt checks out , i would replace your ground wire and ground straps . and while your at it the starter cable , clean all your connections . bla bla .
worked for me on my jeep after swapping out two alternators for my xj (both which i tested on a bench and worked ).
i believe you have the delco alternator which is internally regulated so should be fine if the alternator was checked and works .
if it has the newer nippendenso alt then check the regulator .
Alucard726
PostPosted: Thu Sep 27, 2007 10:11 pm    Post subject: Reply with quote
Thank you very much i'll try that, yeah its the Delco alternator
