| Author |
Message |
RTFS Member
Joined: 21 Feb 2006 Location: Not BFE but I can see it from here in Culpeper
Posted: Fri Sep 28, 2007 4:55 am Post subject: Thanks to Phantum! |
I was in a quandary trying to decide whether or not to swap out the D35 on the XJ with an 8.25 that was available. Everybody was telling me the 8.25 was stronger so I decided to do it. I started having doubts when I found out the 8.25 has an open dif and my D35 is limited slip. Another issue with the brake line caused me to do some more research on the web and my google search came up with http://jeephorizons.com/tech/xjstockspecs.html.
This page told me that the c-clipped 8.25 I had (93) actually has a smaller axle shaft than my non-c-clip D35. That on top of open vs. limited slip and Phantum's comment this past weekend about the availability of aftermarket parts for the 8.25 was enough for me. I decided to put the D35 back in which in turn solved my other issue with the brake line. An added bonus is the vehicle isn't bastardized so ordering stuff from the counter at Autozone won't be a circus act.
Thanks Phantum!
Now is when somebody comes back and says the shaft size was a typo and it's actually 2" _________________ 04 Rubicon with a couple of mods |
| Back to top |
ThePhantum Pissed-Off Admin
Posted: Fri Sep 28, 2007 5:14 am Post subject: |
What was the issue with the brake line? Does it have ABS? _________________
| Back to top |
RTFS Member
Posted: Fri Sep 28, 2007 9:53 am Post subject: |
the body bracket for the rear brake line where the flexible tube connects to the hard line on the 93 Cherokee has a hexagonal hole in it that matches a hexagonal end on the flexible line going to the axle. The 88 has a round hole in that bracket. The hex shape was too big for the round hole so the holding clip wouldn't engage into the slot. _________________ 04 Rubicon with a couple of mods |
| Back to top |
02tj Member
Joined: 16 Jun 2005 Location: Ashburn Va, (Broadlands)
Posted: Wed Apr 30, 2008 11:05 am Post subject: |
Hey Jeff, I know this is a old post but what about a 8.8? I can get them cheap and I know what brackets you need to complete the swap and the brake line issue is an easy fix. Im doing a swap in the xj for the wife this winter just for the disk brakes an LSD. _________________
| Back to top |
jppilot61 Moderator
Posted: Wed Apr 30, 2008 2:07 pm Post subject: |
OK, I'll bite:
How Cheap is Cheap?
I'd like the Disc brakes more than anything else. Drums makes a hard breaking situation a little scary!
My 8.25 does ok with my 32's. _________________
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
RE1801 Slip Yoke Eliminator Kit NP231 |
| Back to top |
02tj Member
Posted: Thu May 01, 2008 1:43 am Post subject: |
I can get the diff w/ disk and LSD for 200-250 _________________
| Back to top |
02tj Member
| Back to top |
02tj Member
Posted: Thu May 01, 2008 1:44 am Post subject: |
| Back to top |
