| Do I rebuild and stick more money in this machine or do I buy new |
| N ew |
27% |
[ 3 ] |
| Rebuild |
72% |
[ 8 ] |
| Total Votes : 11 |
| Author |
Message |
Wild Thing Member
Posted: Sun Sep 30, 2007 6:06 pm Post subject: When do I give up on it and sell |
I have a 1979 Jeep CJ7. At least it used to be. In about 1993 I had the local shop refurbish it. It now has a small block chevy 400, 4bbl, and a chevy manual truck transmission with a ultra low gear with its transfer case.
The engine was rebuilt at that time (at least below the heads). It has a locker in the rear and limited slip in the front. I have revered the front springs. I had a fiberglass body installed.
The engine now uses oil, about a quart a thousand miles. The compression is great, so I think it is the valve seals. The paint is fair and interior is getting a bit beat up. Custom roll bar I like the uniqueness of this machine. But this thing is driving me crazy with the break downs. A gasket goes out in the rear end, drive it home from being fixed, it over heats. I had to have the carb rebuilt this year and the distributor went out this year also. This is a common problem with this machine. One thing after another. I am trying to figure out when enough is enough. Do I have another complete overhaul and rebuild?? Compared to a new price I could do it I suppose, but it never will be a new vehicle but has anyone else done a rebuild and then have a reliable vehicle or do you always have to wonder if you wil get back from a trip?? |
| Back to top |
IBTJn Moderator
Joined: 31 Dec 2004 Location: Just Outside of Portland, OR
Posted: Sun Sep 30, 2007 10:15 pm Post subject: |
I voted rebuild. Small block chev motors are common and a decent motor. I often regret not keeping and rebuilding my SJ Cherokee. That rig was alot of fun! And CJ's are even more fun IMO. I have an '02 TJ now that has some mods (ARB's, RE Lift, 35's, etc. etc.) and I love it. But it'd make a tough daily driver (which it's not). Follow your conscience though, and if it's a daily driver I'd probably be on board with something newer. But if it's not, then I'd probably rebuild it.
 _________________ Links4Jeeps |
| Back to top |
Wild Thing Member
Posted: Mon Oct 01, 2007 5:33 am Post subject: |
| It is not a daily driver, although during the summer it is close to being one. |
| Back to top |
Code3TJ Hacker
Posted: Mon Oct 01, 2007 9:44 am Post subject: |
I'd keep it and fix it too if you have another vehicle.  _________________ Nothing to see here. |
| Back to top |
Wild Thing Member
Posted: Mon Oct 01, 2007 5:10 pm Post subject: |
| I have one for my wife, one for me and then the CJ |
| Back to top |
Duncan Member
Posted: Tue Oct 02, 2007 4:21 am Post subject: |
| Fix it... You don't seem to be short on vehicles so there is no huge rush or anything. |
| Back to top |
coaldigger Member
Joined: 18 Sep 2008 Location: coal seams across the us
Posted: Thu Sep 18, 2008 6:02 pm Post subject: |
DO NOT give up on the jeep took me 12 years to get another one and I bought her in a basket rebuilt motor 304..tranny 3sp dana..frt axle dana 30 rear 44 dana and transfer case spicer......I drive an 04 ranger 2 work daily and will never part with this cj5 oh it is an 80 body 72 frame.......KEEP HER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! _________________ madmike |
| Back to top |
hutchman Captain Kirk
Posted: Thu Sep 18, 2008 6:45 pm Post subject: |
Get rid of the thing...........
somebody needed to vote negative..........! |
| Back to top |
coaldigger Member
Posted: Thu Sep 18, 2008 6:57 pm Post subject: |
URRRRRRRRRR BREAKIN MY HEART........CJ'S R LIKE EX GIRLFRIENDS.... _________________ madmike |
| Back to top |
bulldog67 Member
Posted: Mon Dec 15, 2008 5:20 am Post subject: |
keep it keep it keep it
A CJ7 is for life, unlike a xmas present puppy  |
| Back to top |
EVANLA_33 Member
Posted: Fri Jan 16, 2009 9:52 am Post subject: |
| If the rest of it is strong I would rebuild, then u know what u have. Used motors still can cause problems & new engines are pricey. If u by a new vechile u still may have problems with big payments. Rebuild her! |
| Back to top |
