scratches chin
Goto page Previous  1, 2, 3, 4, 5, 6  Next
badger
PostPosted: Sun Oct 14, 2007 1:33 pm    Post subject: Reply with quote
did some more fitting this afternoon
still have to do some cutting on the inside but the window is trimmed out
the upper rear corner is taken care of
granted i still have some grinding to make it all fit right and get it welded but it seems to be coming together.
One Built XJ
badger
PostPosted: Mon Oct 15, 2007 3:54 pm    Post subject: Reply with quote
well i went out to one of the junkyards on a tip that they had two MJs in the yard.well they did so i found one and got to work
so now i can just cut off the whole rear section and use the Comanche rear half to finish it back off.
One Built XJ
badger
PostPosted: Tue Oct 16, 2007 11:36 am    Post subject: Reply with quote
it lost more weight this morning
started getting the cab ready but i ran out of sawzall blades and cutting disks
One Built XJ
badger
PostPosted: Tue Oct 16, 2007 3:49 pm    Post subject: Reply with quote
my truck seems to be on the Oprah diet.it loses weight then puts it right back on
so now i need to remove the back axle and finish trimming up the cab and back of the Xj to make them match up.
One Built XJ
jppilot61
PostPosted: Wed Oct 17, 2007 2:15 am    Post subject: Reply with quote
How convenient you even found a RED one!
Really enjoying watching the transformation and the design process so well documented in your photos.
Keep sharing your progress!
From all of us a bit to shy to break out the sawzall!
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
badger
PostPosted: Wed Oct 17, 2007 9:50 am    Post subject: Reply with quote
just so there is no more confusing as to what is happening here
still need to trim up the bottom of the cab
the pile of Xj is getting bigger
One Built XJ
badger
PostPosted: Wed Oct 17, 2007 5:32 pm    Post subject: Reply with quote
more work this afternoon
the body lines are still a bit off
the cab half needs to come up about another 1" .so i need to clear out some more material on the inside
the floors almost line up.they are still spread some since i still have to clearance the outer and inner skin some.
window trim
a little more back
more back,like i said still need to trim some of the outer skin
One Built XJ
PostPosted: Wed Oct 17, 2007 7:22 pm    Post subject: Reply with quote
i wish i had more then one vehicle so i could do sweet stuff like this . hard to do it on something you have to drive every day .
looks sweet . building your own frame? tube chassis ? wait and see?
PostPosted: Wed Oct 17, 2007 9:15 pm    Post subject: Reply with quote
you have accomplished a lot in the past few days. Good work
lakeland713xj
PostPosted: Thu Oct 18, 2007 4:47 pm    Post subject: Reply with quote
your neighbors must despise you judging by the trailor...when i lifted mine at my dad they flipped because we did it in the drive way....the signed a petition when we park our boat in the front while serving the motors...apparently a 27 foot hunk of white and stainless is to big to have in a residential neighbor hood....were going to barrow all the boats we can find and park em there....
Jeep cherokee 98 4.0
6.5" rough county
33x12.50 toyo mts
badger
PostPosted: Sat Oct 20, 2007 3:11 pm    Post subject: Reply with quote
well i went over to Harbor Freight to get some more goodies to help the project along
some dollies ,hammer,air flanging/hole punch tool,spot weld cutter, and a magnet welding brace.
One Built XJ
badger
PostPosted: Sun Oct 21, 2007 2:52 am    Post subject: Reply with quote
was feeling bored and now that i have the flanging tool i can't wait to get after it tomorrow morning.
so i played with photochop again.this is pretty much exactly what i wanted in the first place
from here its time to start the square tube chassis and exo cage
One Built XJ
badger
PostPosted: Sun Oct 21, 2007 4:17 pm    Post subject: Reply with quote
another look at work done today
this side is flanged and still needs to be brought in a 1/2"
for the most part the body lines are good.
like i said the bottom still has to be swung in a 1/2".i will still have to do some patch work.the driver side floor was rusted out over top of the frame rail.
i will be able to clean up the inside pretty good and blend it all together
the roof lines are the next big hurdle .from the gutter line down they match(other then the floor pan) but the roof is taller on the Comanche by about 1".so now i will clam shell cut the roof ,cut it down and put it back to match it up with the Cherokee.
One Built XJ
badger
PostPosted: Tue Oct 23, 2007 12:53 pm    Post subject: Reply with quote
so today i did what you all have been waiting for -well some of you anyway
i cut the last bit of cab roof off to start shaping it.this is were that picture of the dollies and hammer come in .
i cut the section off leave just over an 1" above the window
it left me with the interior header still poking up
cut that back next
using the dollies and the slap hammer i started stretching out the roof line
with it tucked under the XJ roof
of course i still have to do some more massaging to make it fit just right.clean up the edges and flanges them .then tack it all together.
i also finished framing out the drivers side rear window
One Built XJ
Duncan
PostPosted: Tue Oct 23, 2007 5:31 pm    Post subject: Reply with quote
Damm... I admire your... Like.. Quickness.
LOL... You are REALLY moving on this thing.
Page 4 of 6
