85 Jeep Cherokee 2.5L 4spd
85XJ09
PostPosted: Sat Oct 06, 2007 10:15 am    Post subject: 85 Jeep Cherokee 2.5L 4spd Reply with quote
I recently bought an old 85 Cherokee and the thing has never failed me. The only issue I am running into is something in the fuel injection is messing up. The little 2.5 doesn't want to start when its cold, there is a clicking noise coming from the SOMETHING in the fuel delivery system (somewhere by the throttle positioning sensor). I was told the throttle positioning sensor was bad, but I figured I would try to get some other opinions before i spend $70.00 on a new sensor. Any ideas? (I could also make a video of what its doing and put it on YouTube or something if I haven't described the problem good enough)
Edit: Also, has anyone here ever done a 350 swap in an 85 Cherokee? If so please, let me know how it went
nate
PostPosted: Sat Oct 06, 2007 1:01 pm    Post subject: 85 cherokee Reply with quote
I had the same problem and it ended up bieng the ignition control module, what the ignition coil was bolted on top of, also you can get a TPS for $24.00 or so at Team Cherokee.
85XJ09
PostPosted: Sun Oct 14, 2007 6:59 pm    Post subject: Reply with quote
thanks a lot, i bought a new coil, ignition module, and a new tps from team cherokee and it runs like a champ now.
Toliver09
PostPosted: Thu Oct 18, 2007 1:57 pm    Post subject: Reply with quote
the clicking is probably the idle speed motor... mine went bad and i had to rebuild it for like 40 bucks
lakeland713xj
PostPosted: Thu Oct 18, 2007 4:50 pm    Post subject: Reply with quote
did any of your friends put a big zip tieon your drive shaft so it slaps your undercarrige when yow drive ...just a suggestion it can happen...trust me....it took 2 days of listening to figure it out...didnt really expect it to be that easy
Jeep cherokee 98 4.0
6.5" rough county
33x12.50 toyo mts
