Radiator Hose - Transmission "Quick Connects"
jdawg2112
PostPosted: Sat Oct 20, 2007 9:33 am    Post subject: Radiator Hose - Transmission "Quick Connects" Reply with quote
Ok - I will probably get flamed for this, but I am doing a radiator swap and I cannot get the transmission line quick connect disconnected from the bottom of the radiator.
Is there a trick to this? I have tried for about 2 hours to no avail. THe thing that is killing me the most is that I put this radiator in about 2 years ago and dont recall having any issues.
Tardis
PostPosted: Sat Oct 20, 2007 9:00 pm    Post subject: Reply with quote
I had the same problem when I changed my TJ motor.
There's a quick disconnect tool kit that removes the lines pretty easily.
Another way to get the line out is to push in on the line hard, and pull apart quickly.
I got tired of dealing with the quick disconnect lines and eliminated them altogether.
I replaced them with standard 3/8" Threaded-Compression fittings.
They work great, and you can take them apart with regular hand tools.
98' TJ, 99' XJ
TheBrat97
PostPosted: Sun Oct 21, 2007 1:12 pm    Post subject: Re: Radiator Hose - Transmission "Quick Connects" Reply with quote
On this forum you will rarely get flamed for anything short of telling someone to go f*ck themselves...everyone has their little pitfalls when they start tearing into a vehicle so don't give up. Jeeps have their PITA's just like every other vehicle.
PostPosted: Sun Oct 21, 2007 3:17 pm    Post subject: Re: Radiator Hose - Transmission "Quick Connects" Reply with quote
Ditto and ditto. You can pick up the tool at most autoparts stores for under $10. But my advice is the same as the above...replace them with compression fittings. It will make life much easier down the road.
Duncan
PostPosted: Sun Oct 21, 2007 4:12 pm    Post subject: Reply with quote
Crap... I wish mallcrawlin was like this Rolling Eyes
