how to make my XJ run cooler
PostPosted: Mon Oct 22, 2007 1:14 pm    Post subject: Reply with quote
Then my guess is a problem with airflow. I know the zjs trap a lot of heat under the hood, hence why they have louvers on the 5.9. Yea its a bigger motor but the 5.9 rams dont have louvers.
I guess you could install louvers if your climate allows. I know they had a write up in the petersens mag a few years ago
lakeland713xj
PostPosted: Mon Oct 22, 2007 6:18 pm    Post subject: Reply with quote
what is a louver?? i googled it and got horiztonal slat to let light in...
Jeep cherokee 98 4.0
6.5" rough county
33x12.50 toyo mts
ehall
PostPosted: Mon Oct 22, 2007 7:17 pm    Post subject: Reply with quote
Try googling for XJ hood louver
PostPosted: Tue Oct 23, 2007 4:47 am    Post subject: Reply with quote
are you running the radiator phantum??? if you dont mind you seem someone who knows what there talking about if you dont mind could you tell me what your running cooling isnt one of my strong points on vechiles...i know hot bad to cold bad in the middle- perfect
Everything I'm running is in the link I posted: http://jeephorizons.com/tech/xj_cooling.html
However, I'm not a good example anymore...between the bumper/winch blocking the grill and the 4.56 gears, I tend to run hot on the highway. It runs about normal on the trail though...which is what matters. Wink
lakeland713xj
PostPosted: Tue Oct 23, 2007 9:26 am    Post subject: Reply with quote
correct me if im wrong but a tranny cooler on a manual wont work right...
6.5" rough county
33x12.50 toyo mts
PostPosted: Tue Oct 23, 2007 9:50 am    Post subject: Reply with quote
I just re-read your original post from the top and noticed this:
ive also noticed the top of my fan shroud is gone
Coupled with the symptoms:
all i kno is a run fine at highway speed and when i stop and stand i get real hot and my dash lights up like a damn christmas tree....
All I can say is...well... thars yer problem. Wink
Without the shroud, the mechanical fan will move much less air across the radiator. Essentially, it's much easier for the fan to move air through the top of the shroud instead of through the fins. At highway speed, air is being pushed into the rad, so the shroud doesn't matter. But at slow speeds, it becomes an important factor.
PostPosted: Tue Oct 23, 2007 12:04 pm    Post subject: Reply with quote
no the trans cooler for a manual wont work, you dont need one for a manual trans
88WOWJ
PostPosted: Wed Oct 24, 2007 9:37 am    Post subject: How to make an XJ run Cooler Reply with quote
At 240 degrees your condenser fan should have cut on. They are supposed to cut on at 215-225 degrees reagardless whether the AC is on or not. I have an 1988 with an electric fan for the fan clutch and I never
have seen it above 206 degrees. My 1991 XJ stays at 208 all the time.
1991 Cherokee Limited
tomynoks
PostPosted: Thu Oct 25, 2007 2:20 pm    Post subject: Reply with quote
A simple trick is to raise the back of your hood a little.. get longer bolts and stack washers or make spacers. This will allow heat to escape easily.
Sounds like you've got more issues than this will solve... but's an easy thing to do.
Tom
'99 XJ Sport
AirAid Intake
PowerAid Throttle body spacer
RE6030 3.5"
1" T-case drop
31x10.5x15 BFG AT KO's
PostPosted: Thu Oct 25, 2007 6:54 pm    Post subject: Reply with quote
How come people arent fully reading the thread? He said both fans are running, at highway speed the temps fine.
tomynoks
PostPosted: Thu Oct 25, 2007 7:09 pm    Post subject: Reply with quote
Guilty as charged!
He just needs a fan shroud i take it?
.....learnin' everyday....
Tom
'99 XJ Sport
AirAid Intake
RE6030 3.5"
1" T-case drop
PostPosted: Thu Oct 25, 2007 11:47 pm    Post subject: Reply with quote
That is correct, try installing a shroud and let us know
jeeppro
PostPosted: Sat Oct 27, 2007 9:04 am    Post subject: Reply with quote
I think your radiator is not cooling efficiently. Even a stock replacement rad will be better than the old one
PostPosted: Sat Oct 27, 2007 9:20 am    Post subject: Reply with quote
If it was a radiator efficiency problem, it would run hot on the highway. Replacing the radiator without fixing the broken shroud first is going to throw money at the problem and not actually fix it.
I'm not saying that replacing the radiator won't help keep the engine cooler...quite the opposite. I highly recommend going to a 3 core all metal rad. It's a good mod...but in this case, it won't solve the problem. Wink
lakeland713xj
PostPosted: Sat Oct 27, 2007 9:52 am    Post subject: Reply with quote
i "ghetto" rigged a fix for my shord to see if its the problem with some thin aluminum to cover the broken top part....also replaced the hoses and re sprayed the radiator...seems to make a HUGE diffrience...im guessing it was like fact thaat the top half of the shroud that iseffin me up heading to a junkyard and gonna snag hopefully a free one
6.5" rough county
33x12.50 toyo mts
Page 2 of 3
