YJ Ignition switch wiring
azdesertrhino
PostPosted: Fri Oct 26, 2007 5:00 pm    Post subject: YJ Ignition switch wiring Reply with quote
I've got a 1987 YJ 4.2L, 5 Speed manual, Tilt wheel, Ugly Green (Oh, I guess that part doesn't matter!)
Something in the column broke loose and the rod no longer engages the ignition switch.
Don't really want to tear into the column right now, just don't have the time. Currently am using a screwdriver to pull the ignition switch in to "ON" and the "Start". Works O.K. but want to rig a temporary toggle switch for the "On" position circuit and then a push button for the starter circuit.
Anyhow, at this point, trying to locate a wiring diagram for the ignition switch wiring. My manual shows the sequence of operation but I have no color code etc for the wiring.
I'm buying a complete FSM but can't get it before Sunday or Monday and was hoping to knock this job out.
Can someone shoot me a picture?
Thanks in advance!!
