Power Steering hose for 2001 GC
lovegun
PostPosted: Fri Nov 09, 2007 2:47 pm    Post subject: Power Steering hose for 2001 GC Reply with quote
Cannot find a pressure hose for a 2001 Grand Cherokee Limited V8. Got one from the dealer that they looked up using the VIN. It is the right length and has all the right bends but the pump side will not thread all the way into the pump. It is definitly not the right hose for that pump. The dealer is clueless. Anyone have any suggestions? Thanks.
tomynoks
PostPosted: Tue Nov 20, 2007 6:12 pm    Post subject: Reply with quote
I'm working on a 2001 GC for a friend. Her's is leaking PS fluid where the hose connects to the pump. That fitting does not look like it screws all the way in. It looks as if it goes about 2/3 of way in and stops. It's not enough to seal the metal tube and the fitting so, that is where it leaks. Is this the same prob you're having?
Thanks,
Tom
'99 XJ Sport
AirAid Intake
PowerAid Throttle body spacer
RE6030 3.5"
1" T-case drop
31x10.5x15 BFG AT KO's
tomynoks
PostPosted: Tue Nov 20, 2007 6:59 pm    Post subject: Reply with quote
By the way, how much was the hose from Chrysler???
'99 XJ Sport
AirAid Intake
RE6030 3.5"
1" T-case drop
