93 Jeep Grand Cherokee with TOYOTA transmission!
PostPosted: Tue Nov 20, 2007 7:29 pm    Post subject: Reply with quote
The Aisin Warner AW4 transmission is an automatic shift, four-speed overdrive transmission used in the 1987-2001 Jeep XJ Cherokee and MJ Comanche models. Its only year in the ZJ Grand Cherokee was 1993, and only with the six-cylinder.
The AW4 is found behind the AMC 4.0L (242 ci) I6 engine. The AW4 is also reputed to have been used behind the AMC 2.5 four-cylinder, though we have never seen this. A similar transmission is used in some Toyota RWD applications, known as the A340.
Gear Ratios for the AW4 are 2.80, 1.53, 1.00 & .75.
The AW4 is a light to medium-duty transmission. Ours, our callers' and customers' experiences with the AW4 are less than stellar. They have a tendency to generate excessive amounts of heat, and are known for unnecessarily consuming more engine power than some other automatics. The shift points in the AW4 feel odd, and the spotty engagement of the lockup torque converter is idiosyncratic.
im pretty sure that solves this little mix up .
PostPosted: Tue Nov 20, 2007 11:02 pm    Post subject: Reply with quote
Its cool dank the 46rh is a pretty decent trans
