How to tell if a 2005 has AWD?
CheapyJeep1
PostPosted: Mon Nov 19, 2007 6:58 pm    Post subject: How to tell if a 2005 has AWD? Reply with quote
I'm looking at a used 2005 grand cherokee with "AWD". It has 48k miles and the guy is asking $11,500 cash. It was previously a rental car (up to 28k miles). It comes with an extended warranty to 100k. but still, I'm wondering if this is a good deal?
If this sounds like an OK deal (knowing it was a rental car)... how can I tell if it has AWD? Is there a badge, marking somewhere.. or do I need to look under the front for something?
PostPosted: Mon Nov 19, 2007 9:35 pm    Post subject: Reply with quote
The easiest way to tell, is the plate around the t-case shifter. What does it say?
CheapyJeep1
PostPosted: Tue Nov 20, 2007 9:00 am    Post subject: Reply with quote
There's no transfer case shifter. He said its all-time 4wd
CheapyJeep1
PostPosted: Tue Nov 20, 2007 9:12 am    Post subject: Reply with quote
Just had a dealer pull it up by VIN, it says "quadratrack full time awd"
PostPosted: Tue Nov 20, 2007 9:33 am    Post subject: Reply with quote
Are you sure? There has to be a way to shift the t-case into neutral for towing purposes!
CheapyJeep1
PostPosted: Tue Nov 20, 2007 4:53 pm    Post subject: Reply with quote
Yeah.. its what the Jeep dealer said based on the VIN - its all-time 4wd. I don't really like that, but its a cheap deal. I guess maybe it shifts out the front axle automatically when you put it into neutral. not sure.
PostPosted: Tue Nov 20, 2007 7:31 pm    Post subject: Reply with quote
most newer vehicles you have to pull the drive shaft or put them on dolly's even if it has a neutral .
