need a new rear end!
azabrnski
PostPosted: Fri Nov 09, 2007 4:18 pm    Post subject: need a new rear end! Reply with quote
I need a new rear end! Coming from New York, my 2000 Grand Cherokee Laredo 4.0 has a lot of rust! I need to replace my wheel bearings and seals because they are loosing differential fluid, and you can see the build up of lubrication on the wheel. I cannot replace these cause I fear that i'll break the bolts on the differential and can't drill and tap cause there really is not much clearance there to begin with! I've come to the conclusion that replacing the rear end is the best bet. If i'm wrong let me know what I can do! If i'm right, lemme know how much i should be looking to spend on this!
PostPosted: Tue Nov 27, 2007 10:31 am    Post subject: Reply with quote
Which bolts are you in fear of breaking? I wouldn't replace my rear end if it only needs wheel bearings and seals!
