2wd suspension
Redyakfly
PostPosted: Tue Nov 20, 2007 2:47 pm    Post subject: 2wd suspension Reply with quote
Have a 2000 2wd drive limited , the leaf packs in the back are almost flat. I am thinking of adding new HD leafs in the back , should I add new springs(stock) in the front as well or am just wasting money on a 2wd??? I will be adding new shocks as well.
PostPosted: Tue Nov 20, 2007 6:00 pm    Post subject: Reply with quote
Does the Jeep sit level or does it sag in the back? That will answer the question of whether to replace the front springs....
Wink
Redyakfly
PostPosted: Tue Nov 20, 2007 6:30 pm    Post subject: Reply with quote
It has a very very slight sag in the rear.....
PostPosted: Tue Nov 20, 2007 6:32 pm    Post subject: Reply with quote
If it's sagging, then replace the rear springs and give it a week or two to settle. If it's still sitting to high in the rear then replace the fronts.
Redyakfly
PostPosted: Tue Nov 20, 2007 7:01 pm    Post subject: Reply with quote
Sounds like a good plan, thanks for the info
