swaping the stock inline 6 for a chevy 350 or other 8cyl
Bowlesy
PostPosted: Sun Dec 16, 2007 3:43 pm    Post subject: Reply with quote
Definately take the stroker over the swap. but if you do let me recommend not going much bigger than the 4.5 or 4.6. from what i've heard the 4.9 and 5.0's don't last too long, but that depends on how you drive it. I'm actually probably going to go for the 4.6. keep in mind also that if you're looking for a way to make your jeep faster that stroking out a 4.0 will be much lighter than stepping it up to a v8. as an added bonus maybe
Franko
PostPosted: Tue Dec 18, 2007 11:34 am    Post subject: Reply with quote
Actually the 4.0 and a 302 with aluminum heads are VERY close in weight. Prob within 10lbs. You could do a ford 281 swap with aluminum block and heads and prob save some weight. Although I would still go with stroking the 4.0 due to cost and ease.
djgrayxj
PostPosted: Wed Dec 19, 2007 8:32 am    Post subject: more info on stroking Reply with quote
Stroking Web Sights
Fast Jeep
http://videos.streetfire.net/video/f190d82f-41e0-4712-a00f-99a300061c4d.htm
Stroker Information
Why not make a 4.6L stroker out of it, you only need a crank, connecting rods, pistons and some machining, and probably injectors and I believe a fuel pressure regulator, and maybe a map adjustment. You could easily do a stroker for under 2000 $. It looks like itís the best way to get power (250~260 hp with a torque curve from hell) out of the old 4 L as long as you are not afraid to take the engine out. Use a 1996 or newer block the blocks were stiffened with extra ribbing and main bearing brace was added.
Web Sights
http://www.angelfire.com/my/fan/stroker.html
http://www.ajeepthing.com/stroker-motor.html
http://www.jeep4.0performance.4mg.com/stroker.html
Aluminum head from Hesco
http://www.hesco.us/
Supercharger
http://www.jpmagazine.com/howto/5472/
Budget 4.5 Build Up
http://www.jeephorizons.com/phpbb/viewtopic.php?t=11808&start=0&postdays=0&postorder=asc&highlight=&sid=4c4783bee2a4a7ca2e7bf49677d6db99
If you want a bored throttle body check this out:
http://www.angelfire.com/my/fan/MustangTB.html
If you want a chip check out Jet chips:
http://www.quadratec.com/products/17608_02.htm
They aren't cheap. I have only heard about the performance gain from these, I have never tried one, but there are plenty of people who have them, perhaps they will pipe in.
gopher383
PostPosted: Fri Jan 11, 2008 4:19 pm    Post subject: New Idea. Reply with quote
I'm just going to go with another XJ inline 6. Whare is a good place to get one cheap but in good running condition, and how much would it cost about? The 350 would be fun but I think the inline 6 has more alure.
PostPosted: Fri Jan 11, 2008 4:51 pm    Post subject: Reply with quote
auto wrecker
