ZJ/XJ parts crossmatch
Goto page 1, 2  Next
wafflesxoxo
PostPosted: Tue Nov 20, 2007 8:07 pm    Post subject: ZJ/XJ parts crossmatch Reply with quote
I own a 95 ZJ with a blown motor (knocks HARD) and great body, and an an 88 XJ with a terrible body and serious interior electronics issues (has a mind of it's own), but a very strong low (125,000 miles) mileage engine and a ton of upgrades front and back (quick detach sway bar, beefier parts all over the place). The motor swap won't be much of a problem, I plan to go with the XJ's head and block with the ZJ's induction, a header and a couple of other things I have for the it.
I'm looking for any kind of helpful tips that might be good to know, things to watch out for, but otherwise I just have one question -- are front side suspensions the same between the two? I haven't gotten to look at them side by side yet but they look identical.
PostPosted: Tue Nov 20, 2007 11:05 pm    Post subject: Reply with quote
the front suspension is the same, but the zj has a low pinion where you xj will more thank likely be high pinion, which is an upgrade
also keep the zj drag link and tie rod steering components as they are beefier
and im sure you know that the water pumps are different
baja zj
PostPosted: Wed Nov 21, 2007 6:38 pm    Post subject: Reply with quote
Didn't they change the ports on the head mid-way through the 98 year?
I think they did.
PostPosted: Wed Nov 21, 2007 8:43 pm    Post subject: Reply with quote
he doesnt have a 98.....
baja zj
PostPosted: Wed Nov 21, 2007 8:59 pm    Post subject: Reply with quote
.........you're right. My bad.
The ports were raised on the head slightly in '91 as well as a cam change and higher flowing injectors.
PostPosted: Wed Nov 21, 2007 10:29 pm    Post subject: Reply with quote
hes keeping the zj intake
and they should mate fine together
wafflesxoxo
PostPosted: Sat Nov 24, 2007 6:30 pm    Post subject: Reply with quote
turns out I'm going to have to either get a new transmission or keep the one from the 88. Will the drive shafts line up the same between the two?
wafflesxoxo
PostPosted: Sat Nov 24, 2007 6:31 pm    Post subject: Reply with quote
Oh yeah, also will there be any problems with the sensors? Should I use the ECM from the 88 or the 93? (turns out the ZJ is a 93 with a door from a 95 Laredo on it.
baja zj
PostPosted: Sat Nov 24, 2007 7:09 pm    Post subject: Reply with quote
wafflesxoxo wrote:
.....any problems with the sensors? Should I use the ECM from the 88 or the 93? (turns out the ZJ is a 93 with a door from a 95 Laredo on it.
well, Ifox2go knows more about these then I, but from what I little I know about Cherokees, the EC units are completly different. You're early one is a Renix (sp?) and the '93 is a little more sophisticated. I think you'll need to stick with the one that is already in the '93.
PostPosted: Sun Nov 25, 2007 3:27 am    Post subject: Reply with quote
Hes correct, computers wont work, and unless your 93 has the aw4 then swapping trans would be a major pain as well
why is the transmissions going to be a problem? the blocks are the same only difference is the accessories, intake etc, essentially everything that is different is still good on the zj and will work
Did a swap similar to this a few years back, except i went from zj to xj
fishjrl
PostPosted: Sun Nov 25, 2007 11:51 am    Post subject: Reply with quote
now someone said that the front suspension is the same
does this mean that a cherokee D30HP will swap out flawlessly with my 93 zj D30LP
PostPosted: Sun Nov 25, 2007 12:48 pm    Post subject: Reply with quote
yep
wafflesxoxo
PostPosted: Sun Nov 25, 2007 3:47 pm    Post subject: Reply with quote
Alright, so as far as the motor goes, I'm replacing the blown ZJ block and warped head with the block and head from the XJ, keeping the intake and injection, power steering pump, a/c from the ZJ, swapping in the swaybar from my XJ and keeping the '93 computer.
Are the sensors the same on the 93 block? (knock sensor and coolant temp. sensor on the left side)
Also, I'm going to take a look at the trannie but I'm reasonably sure it's one of the AW4 variety, but if not should I look for the same combination of transmission and transfer case as is currently on the '93?
Let me explain my position..
The 88 was sold to me real cheap earlier this year, it just needed a little love, a new push rod, new fuel pump, and a new temp sensor, but even so the interior electronics are shot, things short out all the time, sometimes one or both brake lights don't work, the interior is all torn up and there's a few holes in the floor board. The drive train only has 127,000 miles on it.
The '93 is being sold to me at cost of scrap from my boss (I work in the shop at a dealership). It was repo'ed with a busted motor and it's not worth it to him to buy a new motor for it. He wanted to remove and store the transmission and scrap the rest, but instead I'm buying the body and all w/o the transmission for only about $150.
PostPosted: Mon Nov 26, 2007 3:31 am    Post subject: Reply with quote
I just got off work, if i sound like an ass sorry, im tired
Heres the bottom line, when you take out the zj motor, sit it on the floor complete
Remove the xj motor, tear it down to where its just a block, head, oil pan, valve cover, then sit it in the zj engine bay, then its a matter of pulling what you need off the zj motor and putting it on the xj motor
I know the water pumps are different, thermostat housings may be different
PostPosted: Mon Nov 26, 2007 3:32 am    Post subject: Reply with quote
Im still confused as to why you think you need a trans???
the zj trans will bolt up just fine
Goto page 1, 2  Next
Page 1 of 2
