Oil pressure sending unit BROKE ....need help and advice
XJPAT
PostPosted: Mon Nov 26, 2007 12:39 pm    Post subject: Oil pressure sending unit BROKE ....need help and advice Reply with quote
The black tube looking thing broke from the block. whats the best way to remove the piece? since it is broken. Or possibly block it and forget the oil pressure gauge?
97xjcrawler
PostPosted: Mon Nov 26, 2007 8:29 pm    Post subject: Reply with quote
If I remember right..you can unscrew the rest of the oil pressure unit in the picture and replace it with a new one. I broke mine when putting a new oil filter in. I wouldn't disconnect it for good because you never know what can happen...better to see the pressure drop before you have been running the engine dry and overheat the piss out of it
PostPosted: Mon Nov 26, 2007 10:35 pm    Post subject: Reply with quote
by overheat the piss out of it you mean seize it .
monkeyman3875
PostPosted: Tue Nov 27, 2007 8:53 am    Post subject: Reply with quote
Holy crap, that happened to me less than two weeks ago! Nice timing.
Is it a simple unscrew/replace job, or is there more involved?
-1997 Stock XJ
-4.0 L
-4-speed automatic
mattbred
PostPosted: Tue Nov 27, 2007 12:26 pm    Post subject: Reply with quote
Unscrew and replace. did it myself.
97xjcrawler
PostPosted: Tue Nov 27, 2007 2:43 pm    Post subject: Reply with quote
Well wouldn't you first overheat it...then seize it. Not trying to say your wrong Brad
