Cylinder 3 misfire (2001 Cherokee Sport)
broooooooce
PostPosted: Thu Jun 25, 2009 11:27 am    Post subject: Cylinder 3 misfire (2001 Cherokee Sport) Reply with quote
Hi.
Recently, my jeep has been extremely rough starting and this caused the engine light to come on so I went and got the code checked. Cylinder 3 misfire it said. Well, 3000 miles ago, I had changed the plugs myself (but not the coils or the coil assembly). Well, I just decided to make sure the thing was gapped correctly and it was and I wiped off a tiny bit of build up on the spark plug, put it back in. I only did this for cylinder 3. I disconnected/reconnected the battery to get rid of the engine light and it drove and started fine for a while until today when it started rough again and low and behold, same thing cylinder 3 misfire.
Autozone troubleshooting ticket based on my code says it's probably:
Ignition system fault - plugs/ignition wires/coil
Vacuum leak
Injector Fault
high or Low fuel pressure.
I haven't changed the coils or the coil assembly thing. But it seems like the coils are just springs inside of a rubber "boot" and it strikes me as unlikely that these suddenly just failed? Who knows though.
150,000 miles on it and it idles just a tiny bit rough, but always has.
I don't know jack about vacuum leaks or how that would tie into things.
Could it be the injector on the 3rd cylinder?
What does high or low fuel pressure mean?
I would be very grateful if someone would suggest to me the most cost-effective path by which I can troubleshoot and eventually fix this.
Thanks,
Bruce
broooooooce
PostPosted: Sun Jun 28, 2009 1:36 pm    Post subject: Reply with quote
replaced coil pack and it ran fine for a couple days and then the light comes back on today. Get the code checked and its P0118 - Engine coolant temperature sensor input above maximum acceptable voltage. Also, the temp gauge goes out intermittently. I am fairly sure that this sensor may be the culprit of the misfires and stuff because it tells how rich a fuel mixture to shoot into the cylinders (I think....)
Will replace it tomorrow and report my results back here.
Bruce
broooooooce
PostPosted: Mon Jun 29, 2009 8:03 pm    Post subject: Reply with quote
with the new coil pack, my oil pressure is higher (?!) I don't know how or why but it would sit between 10 and 40 on the gauge usually and now it tends to be 10-50 but mostly above 30.
It also drives a LITTLE different in an unexplainable way, it just feels a bit different--not better, but not necessarily worse.
So far so good, the engine light actually went off of its own accord just before I changed the coolant temp sensor and so far everything is ahite.
Cherokeeper
PostPosted: Thu Jul 02, 2009 9:45 am    Post subject: Reply with quote
Broooooooooooooooce:
I replied to an OLD OLD post that you had posted to.
Hopefully it will help you answer the question of rough starts when hot.
01 XJ 4x4 auto 2dr.
3" lift, TJ front swaybar, rear swaybar removed
Mastercraft 31's on Cragar Black D 8" rims,
1" TC drop, Iron Rock rock sliders, custom grill guard
