need some help about my fuel pump
87xj4x4
PostPosted: Tue Dec 04, 2007 4:55 pm    Post subject: need some help about my fuel pump Reply with quote
i have an 87 cherokee 4.0 and my fuel pump is hiting the inside of my tank. when i touch the main fuel hose that goes into the tank i can move the pump around. does the pump mount in the tank a specific way????? also it can slide in and out a bit and that is creating a leak.. any ideahs on how to fix????
PostPosted: Tue Dec 04, 2007 5:17 pm    Post subject: Reply with quote
I'm not sure what you're saying, but it sounds like the gasket is shot.
PostPosted: Tue Dec 04, 2007 5:51 pm    Post subject: Reply with quote
the ring broke off the tank along with the rubber o-ring . im guessing . take a picture
87xj4x4
PostPosted: Tue Dec 04, 2007 8:13 pm    Post subject: Reply with quote
how does the pump mount in the tank?? mine is fore sure moving around
and leaking
PostPosted: Tue Dec 04, 2007 8:29 pm    Post subject: Reply with quote
The large ring holds the pump in place by sliding under the tabs. There should be a rubber gasket between the ring and the tank. With the ring removed you should be able to pull the sending unit and pump right out.
This will help you!
Fuel Pump Removal & Installation
