I still have a mysterious Clunk under HARD Acceration
jppilot61
PostPosted: Mon Dec 17, 2007 3:52 pm    Post subject: Reply with quote
I thought they looked pretty beefy compared to the stock ones!
I decided against the Polyurethane after market ones because others made statements about them making vibrations and noise more noticible than rubber.
I figured I'd change them again in 4-5 years, if need be . . . for a little quieter highway ride!
Original stock rubber ones lasted 15 years although most of those weren't off road.
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
DavidXJ
PostPosted: Tue Dec 18, 2007 4:38 pm    Post subject: Reply with quote
I'm a strong advocate for the stock engine mounts because they do such a better job at eliminating engine vibration than the polyurethane, but...
Has anyone tried the rubber circular motor mounts like the ones in the previous pictures. If so, do they eliminate engine vibration like they claim, or are they almost as bad as the polyurethane? Offroad driving can sure rip through a set of stock mounts pretty quick.
PostPosted: Wed Dec 19, 2007 2:51 am    Post subject: Reply with quote
I know the MORE Bombproof mounts are supposed to be tough as all get out and specially designed for offroad wear and tear, and that's what I'll be looking into when mine decide to fail. They look to be great replacements compared to factory (don't know how easy it is to get to the mounts tho...).
jppilot61
PostPosted: Wed Dec 19, 2007 3:50 am    Post subject: Reply with quote
I have no taken it off road since the install but my gut impression so far is that everything seems louder and more vibrations now than before with stock motor mounts. (Absent the loud CLUNK though!)
I can only imagine that the MORE Bomb-Proof are tougher/louder than stock but not as tough or loud as POLY.
I think they are in between.
As I said the install was not as difficult as I anticipated other than a couple of typical bone-head mistakes.
One Saturday morning of aggravation, a good floor jack and a sturdy block of wood to cushion oil pan from jack.
1992 XJ Laredo
PostPosted: Wed Dec 19, 2007 5:37 am    Post subject: Reply with quote
Yeah, I'm gonna do more reading up on MORE to see what's best. I've read about people and the polyurethane problems, so rubber sounds much better.
But this is still moot. If I do anything with 'em it'll probably be put in storage until I actually develop a problem anyway. Mr. Green
CACTUS
PostPosted: Fri Jan 18, 2008 6:23 pm    Post subject: Reply with quote
I HAVE SIMILAR PROBLEM ON 86 JEEP CHEROKEE- 6CYL 4.0=IT GOES CLUNK-CLUNK -CLUNK - IN TRANSMISSION AREA= TOOK IT TO MECHANICK AND REPLACED RIGHT ENGINE MOUNT=SAID OTHER ONE AND TRANSMISSION MOUNT OK==PROBLEM STILL PERSISTS BUT NOT AS BAD--GOES CLUNK CLUNK CLUNK ON ACCELERATION OR IN LEFT TURN, NOT ON RIGHT TURN, IN RITHUM WITH ENGINE SPEED= CAN YOU HELP? CACTUS
PostPosted: Fri Jan 18, 2008 6:45 pm    Post subject: Reply with quote
Turn off caps lock.
Get a second opinion on the other mounts. Also check the axle and driveshaft ujoints.
PostPosted: Sat Jan 19, 2008 12:02 am    Post subject: Reply with quote
for the price of Cherokee engine mounts as a rule if you change one you change them all .
lakeland713xj
PostPosted: Mon Jan 21, 2008 11:49 am    Post subject: Reply with quote
some of you guys problems sound like bad u joints
Jeep cherokee 98 4.0
6.5" rough county
33x12.50 toyo mts
