loose steering wheel
jazziebone
PostPosted: Tue Dec 11, 2007 12:28 pm    Post subject: loose steering wheel Reply with quote
I am having a problem with the steering column moving in all directions, about 1", from the automatic gear shift arm up toward the steering wheel.
Everything use to be solid and tight, now I am able to move the upper portion of the steering column by placing pressure on the outside of the steering wheel as I am driving. It does this in all of the adjustable positions.
Its pivioting in the center of the column adjacent to the gear shifter.
I can't figure out how to access this area to see what might be loose.
Is there an adjustment somewhere?
Any help will be greatly appreciated.
PostPosted: Tue Dec 11, 2007 5:12 pm    Post subject: Reply with quote
Sounds like the column is shot.
That happened to a buddy of mine. We were in his Blazer going over some large rocks and the thing just gave. It started pinching some of the wires inside and started to smoke. I hopped out and pulled the battery cables off, stopped the smoke. We had another buddy with us, so they left to get another column from home. I threw it in on the trail and we drove home. Cool
Yours doesn't sound as bad as that, but that's what I would expect to happen if you don't replace it!
