94 Jeep Wrangler needs HELP!
Funeral Jeep
PostPosted: Fri Dec 14, 2007 2:36 pm    Post subject: 94 Jeep Wrangler needs HELP! Reply with quote
I have a 94 jeep Wrangler automatic 4 banger that ever since I brought her home the temp gauge and voltmeter are always in the red. The jeep has not over heated at all the needle on both gauges is in the red. Then she wouldn't start at the first try unless the check engine light went on. Finally the last straw with her was when I was driving home she stated jerking like she was struggling for fuel or power. I changed the cap, wires, plugs, fuel filter and was going to change the thermostat but haven't done that as of yet. I do NOT want to part with this jeep so any help would be great. Thanxs everyone
qkslvr_95yj
PostPosted: Sat Dec 15, 2007 1:49 pm    Post subject: Reply with quote
check the computer...
i had similar problems, changed the computer, seemed to work.
My94YJ
PostPosted: Tue Apr 15, 2008 9:28 am    Post subject: Reply with quote
You may have fixed it by now, but it sounds like problems I was having, but the MAP sensor went bad. Try replacing the map sensor.
