swaping the stock inline 6 for a chevy 350 or other 8cyl
Goto page 1, 2  Next
gopher383
PostPosted: Tue Nov 20, 2007 5:27 pm    Post subject: swaping the stock inline 6 for a chevy 350 or other 8cyl Reply with quote
My 2000 XJ is on its last legs as far at the motor goes, and I'm trying to find a good swap (cheapish) for when it comes time to replace it. I've heard rumor of chevy 350's being put in fairly easily and was wondering what parts I would have to get to sync it with my auto-trany, I have no clue where to look. Also I'd like to know what other options I can look into. Thanks.
badger
PostPosted: Tue Nov 20, 2007 5:38 pm    Post subject: Re: swaping the stock inline 6 for a chevy 350 or other 8cyl Reply with quote
ya the 350 will fit but going in cheap is not a word i would use.whats so wrong with putting another 4.0 in it.oh and since its a 2000 (in most states) the motor that you would replace yours with would have to be from the same year or newer.try looking up the price of a used 2000 or newer 350 Vortec.
One Built XJ
gopher383
PostPosted: Tue Nov 20, 2007 5:55 pm    Post subject: Reply with quote
I can get a Chevy 350 discounted for around 1300 due to family working for a chevy dealership. I'm more so looking for the parts needed to put it in correctly. As for another 4.0, I need more power. My Jeep is the rescue vehicle for my dumber friends XJ's when they decide to get stuck.
PostPosted: Tue Nov 20, 2007 6:18 pm    Post subject: Reply with quote
I'm not sure where you heard it's failry easy and cheap to swap a 350 into an XJ....because it's neither. Regardless of the cost of the engine, it's going to be time consuming to do, expensive to get it right and you'll need strong fabrication skills to get it done. First of all, like Badger said, the engine going in has to be the same year or newer. Meaning that you would need not just the motor, but also the computers and all the sensors intact.
Next the 350 has to sit lower than the 4.0 in order to get the hood closed. So the existing locations of the motor mounts are in the wrong place. They need to be cut out and new ones welded in.
The overall length of the 350 block causes problems both at the radiator (which will also have to be replaced...it's inadequate to cool a SBC) and the location of the distributor causes issues at the firewall. Again, neither is insurmountable, but both require some significant fabrication.
Also, due to the small size of the engine compartment, you're choice in exhaust manifolds/headers is fairly limited...mainly being expensive custom headers or low performance late model manifolds.
The best option to get more power "on the cheap" is to pull your 4.0 and stroke it. That way you retain the existing computers/sensors, it will cost a lot less and everything is pretty much bolt on. Hell, if you grab another 4.0L out of a junkyard and stroke it ahead of time, you can swap it in a day.
htttp://www.jeep4.0performance.4mg.com/stroker.html
PostPosted: Tue Nov 20, 2007 7:25 pm    Post subject: Reply with quote
to sync it up with your auto tranny your gonna want to sell the one you have and get a 4l60e . i don't think anyone makes a bell housing for it and it would just blow up .
a stroker 4.0 is the direction i would go or perhaps a turbo with a fresh engine .
the 350 is alot of work , personally i don't think the uni-body would hold up well unless you strengthened it up a lot .
the 4.0 shouldn't have problems pulling out your friends , you can't tell me in 4low you run out of power before you run out of traction .
badger
PostPosted: Tue Nov 20, 2007 10:08 pm    Post subject: Reply with quote
actually the AW4 can easily handle the newer Vortecs .Its the same trans that came in the Turbo Supras.
One Built XJ
PostPosted: Wed Nov 21, 2007 11:57 am    Post subject: Reply with quote
Ditto...and I seem to remember seeing that Advance Adapters makes a bell housing for a 350/AW4 conversion...
PostPosted: Wed Nov 21, 2007 6:30 pm    Post subject: Reply with quote
i read on novak conversions that they wont even bother making a bell housing for a v8 with the aw4 simply because it wont take it . i personally am not a fan of the aw4 , get a bell housing if you want .
badger
PostPosted: Wed Nov 21, 2007 7:22 pm    Post subject: Reply with quote
the AW4 can easily handle in up of 400 horse power.as i stated above the Supras used the same trans.guys who build drag Supras use the AW4 so this would lead me to believe NOVAK is a bunch of idiots that have no clue as to what they are talking about.
One Built XJ
PostPosted: Wed Nov 21, 2007 7:33 pm    Post subject: Reply with quote
The problem is not the AW4, it will handle the torque and HP just fine. The issue is with the NP231/NP242 tcase...it will pretty much shred. Personally, if I was doing it, I would go with the full drivetrain out of late model Chevy 4x4 truck.
But the fact is, no one (including me) is recommending doing the conversion in the first place. Not when, you could spend less money and do less fabrication stroking the 4.0L to 4.5L. Hell, you could even go as far as stroking it to 4.9 or even 5.0L...and I suspect you would still spend less money than on a SBC conversion...
gopher383
PostPosted: Sun Nov 25, 2007 9:52 am    Post subject: Reply with quote
What would have to be done to stroke the motor? I already have to fix the 6th cyl because its shot. How much is something like this lookind to cost?
fishjrl
PostPosted: Sun Nov 25, 2007 12:22 pm    Post subject: Reply with quote
you can get kits for about $800 as a base line kit and about $1000-1200 for all the options. thats if you do it yourself. labor is a lot of dough and it might cost the same to have someone teach you how to rebuild a motor.
you can also get many of the parts out of a junkyard
badger
PostPosted: Sun Nov 25, 2007 12:32 pm    Post subject: Reply with quote
or for a little bit more then a rebuilt 4.0 you can get a pre-built stroker from several companies.
One Built XJ
PostPosted: Mon Nov 26, 2007 10:32 pm    Post subject: Reply with quote
pre-built stroker http://www.golenengineservice.com/html/jeep_off-road.html
build your own http://www.lunghd.com/Tech_Articles/Stroker/Stroker.htm
http://www.rockcrawler.com/techreports/stroker40/index.asp
http://www.jpmagazine.com/tech/engine/index.html
there are a couple other sites out there about strokers . also four wheeler magazine just did a build up for the 4.0L jeep stroker . jp also recently did one .
Chevyk30
PostPosted: Wed Nov 28, 2007 5:55 am    Post subject: Reply with quote
I also vote for the stroker 4.0L... you should be able to get enought power to tear your whole drivetrain apart. Check out this site.... http://www.jeep4.0performance.4mg.com/stroker.html I have heard of guys putting v8's in cherokee's, I think it was jp magazine had a write up a few years back, so yes, it can be done, if it is worth it, that is all up to you... another idea, if you want a v8 powered jeep, get a cj or a wrangler, they are much easier to put a v8 in than a cherokee....
Goto page 1, 2  Next
Page 1 of 2
