Transfer case problems
arxj
PostPosted: Sat Jan 05, 2008 9:00 pm    Post subject: Transfer case problems Reply with quote
I bought a 1990 jeep cherokee for parts. I have a 1996 model will the transfer case match up? The wiring looks different and i'm not sure it will work does any one know for sure?
PostPosted: Sat Jan 05, 2008 9:10 pm    Post subject: Reply with quote
The transfer cases will bolt up. However, the 90 is an OBDI system and the 96 is an OBDII. That's why the wiring doesn't match. The only real difference that I can think of in the wiring would be speed sensor though...so you should be able to wire it in.
PostPosted: Sat Jan 05, 2008 11:08 pm    Post subject: Reply with quote
The 90 has a switch for the vacuum disconnect front axle that has air lines coming out of it. The same location on the 96 should have the 4wheel indicator switch in it. You can just swap those. You can also just switch the speed sensor. Are they both the same model t-case?
tag
PostPosted: Sat Jan 12, 2008 12:47 pm    Post subject: Reply with quote
You may find this useful, http://www.opiebennett.com/images/Jeep/D4-ford9-swap/Day%2015/np231.htm
