Is it wise to eliminate catalytic converter?
OC_Charlie
PostPosted: Wed Jan 02, 2008 4:07 am    Post subject: Is it wise to eliminate catalytic converter? Reply with quote
Happy New Year Everybody. My exhaust is shot and when I replace it I was wondering about getting rid of the Cat. Converter. I have a 95 ZJ with the 5.2
V8 and my goal is to have a better sounding exhaust. I don't care about milage. I have heard about O2 sensor bypass but I'm not real clear about what it will do. Any suggestion appreciated.
badger
PostPosted: Wed Jan 02, 2008 6:23 am    Post subject: Reply with quote
No its not wise its there for a reason.Leave it on and get a Flowmaster if your looking to change the sound of it.
One Built XJ
OnAll4s
PostPosted: Wed Jan 02, 2008 9:41 am    Post subject: Reply with quote
You can also put on a high-flow cat which will change your exhaust sound, and still keep you legal.
PostPosted: Wed Jan 02, 2008 10:25 am    Post subject: Reply with quote
I hollowed out the cat and installed a Flowmaster on my 94 ZJ 5.2. Been running it for 3-4 years. It runs and sounds awesome! No change in mpg's. I would have removed the cat, but it needs to be there for visual inspection. Wink Do it!!! Mr. Green Just make sure it'll still pass inspection.
OC_Charlie
PostPosted: Fri Jan 11, 2008 2:17 am    Post subject: Reply with quote
I hacked off the Cat and put on a flowmaster muffler and It sounds sooooo goooood. There's a BIG difference in sound with and without the Cat.
PostPosted: Fri Jan 11, 2008 8:24 am    Post subject: Reply with quote
thumbs
PostPosted: Fri Jan 11, 2008 8:09 pm    Post subject: Reply with quote
My cat has been on the scrap pile for years.. there is no visual inspection here so I dont need it at all.. I did however have a bung welded into the pipe where the cat was so I could screw in the o2 sensor ...
I get crap mileage but I have a worked over 5.2 with 35" tires and 4:56 gears.. Mr. Green
PostPosted: Sat Jan 12, 2008 1:11 am    Post subject: Reply with quote
some times you can get a dummy o2 sensor , some engines it works some it doesn't
