weber carb
oldwindsurfer
PostPosted: Wed Jan 02, 2008 7:11 am    Post subject: weber carb Reply with quote
Bought a 1990 YJ with 4.2 and weber carb conversion.Problem is it idles at 2000 rpm if you tap the pedal it will go down to 900 rpm but as soon as you give it gas it goes back up to 2000.This happens when it is cold or hot.Do I have a choke problem(if so how do I fix) or do I need a spring of some type to pull it back. I checked and nothing seems to be binding.
PostPosted: Wed Jan 02, 2008 10:31 am    Post subject: Reply with quote
Is it 2 or 4 barrel? I would start by spraying off the linkage with carb cleaner, then apply a light lubricant. It may help.
oldwindsurfer
PostPosted: Wed Jan 02, 2008 11:55 am    Post subject: weber Reply with quote
Will the Nutter bypass help? Its a two bbl.
Charles64
PostPosted: Sat Feb 02, 2008 9:45 am    Post subject: Cold Air Intake Reply with quote
Have an 89 YJ with a 4.2 and Weber Carb as well. Was curious if anyone has changed the intake to inure cooler air vs how hot it gets under the hood when 4 wheeling for a long period of time. Was thinking a Snorkle of some sort might do the trick or a hood scoop (not sure of the hood scoop though, water and sand access). Will consider all ideas, thanks in advance.
89 YJ, 4" Rough Country, 3"Body Lift, Weber Carb, 33x12.5x15 Trexus , Posi-Lock, Slip-Yoke Elimiantor, waiting on $$$$'s to continue
