strange electrical issue. wrong bulbs light at wrong time...
generalleexj
PostPosted: Sat Jan 12, 2008 3:32 pm    Post subject: strange electrical issue. wrong bulbs light at wrong time... Reply with quote
okay well i fixed my flasher problems, the lights flash correctly but now the wrong bulbs light up
symptoms...
front-
when i turn just the parking lights on, one of the driver side turn signals stays illuminated and on the passenger side NOTHING lights up at all. when i turn the turn signal on left the driver side front flashers work correctly but when i turn the right flasher on, nothing happens on the pass side.
rear-
the driver side parking light illuminates as well as the 194 bulb next to it on the side of the jeep. but on the pass side, nothing lights up at all, but all the brake lights work fine, i dont understand and im stumped, could the only thing it could be is ground ??
ive replaced literally every front end bulb as well as in the rear, and i also put new flashers in for the hazards and turn signals, ..
also, i put new battery terminal clams on and made sure that the ground to engine block is in decent condition which it is... does anyone have expierience with this issue/ ??? any suggestions would greatly help
