how well are 35's with a 4" SA lift?
TJRobbie00
PostPosted: Sat Jan 19, 2008 2:13 pm    Post subject: how well are 35's with a 4" SA lift? Reply with quote
does anyone on here have 35's with a 4 inch SA lift? and stock axles locked? if so have you had any problems?
i want to get bigger tires, but dont want to get a bigger lift... or should ijust stick with 33's?
IBTJn
PostPosted: Sat Jan 19, 2008 10:42 pm    Post subject: Reply with quote
I run the RE-Superflex 4.5" short arm with 35's and needed to do a couple of short hockey pucks on the front axle. I rubbed just a hair at full flex. But you have to remember, the 4.5" RE kit netted me about 5" after it settled. Throwing 35's under a different brand 4" lift you'll likely rub.
I also have ARB's selectable lockers f/r with a D30/D44 and 4.56 gears. It's been a decent combo' for me and my wheelin' preferences. You can probably do 35's if you do a 1" body lift...but be prepared to rub the fronts. And also keep in mind my 35's are more like 34's (Cooper STT's). BFG's and some of the other brands are full 35's more often than not. And if you have a D35c rear axle, I'd forget it completely if I was you.
Hope that helps. Wink
TJRobbie00
PostPosted: Sat Jan 26, 2008 10:40 am    Post subject: Reply with quote
thanks for the feed back! thumbs
decided to stick with 33's i forgot about have to regear and all its just not worth my time or money
kizer
The Link Meister
The Link Meister
PostPosted: Tue Jan 29, 2008 4:35 pm    Post subject: Reply with quote
Gimmie my hockey pucks back I need them for my setup. Mr. Green
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
