Do I have the wrong Steering Stabilizer?
TJ99
PostPosted: Thu Jan 24, 2008 5:23 pm    Post subject: Do I have the wrong Steering Stabilizer? Reply with quote
I have a 99 Sahara TJ and I've got a Skyjacker Steering Stabilizer that I'm not sure about. It's kit #7119...the kind that comes with mounting brackets and U-bolts. I thought I was getting a replacement that just slipped right in, but it appears this bolts around the tie rod assembly with the U-bolts in some way.
Anyone familiar with this? Is this a replacement, or an add-on?
PostPosted: Thu Jan 24, 2008 7:45 pm    Post subject: Reply with quote
An oem replacement would bolt straight through the drag link. What you have will work though!
PostPosted: Thu Jan 31, 2008 10:28 am    Post subject: Reply with quote
What did that setup cost you? If it's more than $30, send it back. You can get an OE replacement...actually better than OE...from most local auto parts stores. There's a Monroe steering stabilizer out there retails for $26 if I remember correctly. Direct bolt on replacement for the stock one.
