Low Pinion, High Pinion, Same Carrier?
terryh80
PostPosted: Tue Jan 22, 2008 2:38 pm    Post subject: Low Pinion, High Pinion, Same Carrier? Reply with quote
Is the Dana 30 Low Pinion and High Pinion using the same carrier?
quadna71
PostPosted: Tue Jan 22, 2008 2:58 pm    Post subject: Reply with quote
yup. when i ordered mine from quadratec i mentioned that i only saw the one listed for the d30 - and nothing for a high-pinion 30. they told me that they were the same and sure enough it worked perfect for her hp30.
2003 TJ Sport
terryh80
PostPosted: Tue Jan 22, 2008 5:21 pm    Post subject: Thanks Reply with quote
I was wondering from what I saw but wanted to be sure. Thanks. Now if I can just find the carrier. I found a lot of the 3.55's
DankNesS
PostPosted: Tue Jan 22, 2008 5:33 pm    Post subject: Reply with quote
why cant you just flip a LP? cant you take the axle tubes off the carrier and flip it and use it as a HP? i think im lost Neutral
PostPosted: Wed Jan 23, 2008 1:27 am    Post subject: Reply with quote
It'll cause your gears to turn backwards.
terryh80
PostPosted: Wed Jan 23, 2008 3:02 pm    Post subject: Reply with quote
Does that mean you could hit 80 in reverse? Very Happy
PostPosted: Wed Jan 23, 2008 6:43 pm    Post subject: Reply with quote
Aside from the gears turning backwards, the difference between the LP and HP is s that the pinion gear meshes with the ring gear in a different (lower) location. That difference in mesh point makes the LP much more prone to housing flex then the HP.
DankNesS
PostPosted: Mon Jan 28, 2008 11:47 am    Post subject: Reply with quote
word. i knew what the differance was just wasnt sure if you could flip an LP
PostPosted: Thu Jan 31, 2008 10:24 am    Post subject: Reply with quote
You'll also have lubrication problems as the oil won't reach everywhere it needs to be to keep things running smooth and cool.
5.9 andy
PostPosted: Thu Jan 31, 2008 9:45 pm    Post subject: Reply with quote
ehirner wrote:
You'll also have lubrication problems.
avoid those at all cost!! lol
