Auto Transmission
WMH
PostPosted: Thu Jan 31, 2008 1:10 pm    Post subject: Auto Transmission Reply with quote
I recently bought a 98 TJ. The Transmission does not want to shift to second until it warms up. After that everything works fine. It takes about 3 min. run time before it works properly. Any ideas ????
TJRobbie00
PostPosted: Thu Jan 31, 2008 1:46 pm    Post subject: Reply with quote
well i have a 5 speed...
but i do know that my tranny wont go into second when its cold.
kirkwood007
PostPosted: Mon Feb 11, 2008 4:39 pm    Post subject: Reply with quote
I had the same problem and mine was getting bad. I did a drain and fill and replaced the filter on my auto trans and used Valvoline MaxAtf (Since I work for Valvoline) and now my shifting is fine right out of the gate in the morning. It was 14 here this morning and mine never stalled whined or anything. Grab the Haynes manual though for this job. I didn't and I ran into a couple of small snags.
WMH
PostPosted: Wed Feb 13, 2008 3:03 pm    Post subject: Reply with quote
The fluids in this jeep have been recently changed. Not sure about additives. I think I'll try that. This jeep continues to function properly after it warms up.
kirkwood007
PostPosted: Fri Feb 15, 2008 7:20 pm    Post subject: Reply with quote
Mine was doing the exact same thing! Did you replace the filter with the fluids? I recommend taking it somewhere like Valvoline Instant Oil Change and getting a flush. They won't replace the filter so I would also check some other places in your area that can do both. Just cause I work there doesn't mean I will say they are the only place to go.
