Steering Stabilizer
arxj
PostPosted: Mon Feb 04, 2008 12:16 pm    Post subject: Steering Stabilizer Reply with quote
I have done everything i can think of to stop my cherokee from the death wobble. The only thing I havent done yet is add a steering stabilizer kit to it. Its a 96 with a three in lift kit with 31x10.50 tires. Will adding a steering stabilizer help out any?
quadna71
PostPosted: Mon Feb 04, 2008 1:37 pm    Post subject: Reply with quote
i'm not sure it'll eliminate the death wobble, but it may help mask it. usually they aren't the root of the problem, but a good stabilizer will help keep the after-effects to a minimum.
what sort of things have you done to try and fix the DW? worn control arms bushings, egged out tie rod ends, poor wheel balancing, and loose/damaged trackbar bushings are usually the culprits. i'd start with checking the torque on the trackbar and control arms, then try rotating tires to see if there is a change (rebalance if there is), and finally look into getting some eccentric-cam lower control arm mount bolts/washers to maybe reposition your front caster into specs. some axles have the brackets mounted in such a way that even the smallest caster changes produce problems.
good luck!
chris (thinks that most stabilizers are pretty much the same, but has had good luck with munroe)
2003 TJ Sport
uvaldetxj
PostPosted: Tue Aug 12, 2008 12:26 am    Post subject: DW Reply with quote
If you buy a good quality SS you'll mask the DW.
Alot of people are going to tell you to fix the problem
correctly, but sometimes the funds aren't available.
Like the previous reply said, DW can be caused by many
things including but not limited to, Stabilizer, TRE's, Balancing,
Alignment, etc.
If I were you I would replace the steering stablizer, if it doesn't
completely solve it try rotating your tires, and if you can have
them rebalanced.
2006 LJ Soft Top
4 Inch Bastard
33 BFG MT
14,XXX
Stock Everything Else.
1987 XJ 2 Door-Chopped Top
3 Inch Rusty's
33 BFG MT
Dana 44 Rear-Lincoln
173,XXX
Still Running Solid.
uvaldetxj
PostPosted: Tue Aug 12, 2008 12:35 am    Post subject: DW Reply with quote
Oh, and check out your tracbar. The axle side bolt may be loose, or maybe the end on it is going bad.
2006 LJ Soft Top
4 Inch Bastard
33 BFG MT
14,XXX
3 Inch Rusty's
33 BFG MT
173,XXX
