weird nise at 2200 rpm
jeepin419
PostPosted: Mon Feb 04, 2008 11:53 pm    Post subject: weird nise at 2200 rpm Reply with quote
i have a 95 4door 6cyl, when driving in any gear it makes a noise almost live a cv vibration. could it be my pinion angle???? note. i have the slip yoke elimitator kit
PostPosted: Tue Feb 05, 2008 6:15 pm    Post subject: Reply with quote
if you ahve a slip yoke eliminator , what size lift do you have ? have you shimmed the axle at all ? are your u-joints with in tolerance angles .
find the angle off the rear yoke , drive shaft and t-case yoke . tell me those and i can tell you if your angle is wrong .
jeepin419
PostPosted: Wed Feb 06, 2008 2:05 pm    Post subject: Reply with quote
i have a 6inch lift with the ford 8inch rear axle and my t-case angle is 3degrees, the rear pinion is 8degrees, and the drive shaft is 12 13degrees
