temp??? whats hot????
jeepin419
PostPosted: Tue Feb 19, 2008 3:13 pm    Post subject: temp??? whats hot???? Reply with quote
my jeep runs consistant at 220. is this hot for a jeep???
everytime i stop and park it leaks like its overheating.
DavidXJ
PostPosted: Tue Feb 19, 2008 4:29 pm    Post subject: Reply with quote
Normal operating temps are between 195 and 210, so 220 is a little high. All the Cherokees I've had experience with run at a constant 210, unless pulling hard up a hill, in which case they may exceed that to about 220 - 225 temporarily.
What do you mean by it leaks like it's overheating? Is it boiling over and the overflow bottle is overflowing? Or is there a little puddle of antifreeze under the engine when you park like your water pump is leaking?
PostPosted: Tue Feb 19, 2008 8:23 pm    Post subject: Reply with quote
what year is your jeep ? if you don't have a normal rad cap and you have the little pressure bottle up by your passenger side door go get a new rad cap .
if you have another car with a 14lbs rad cap and you have the normal open cooling system then borrow it for a day or something or just go buy a new rad cap.
start there , mine did that when i first got it . ripped through some deep alkalie sand and as soon as i stopped it would overheat , just a bad cap .
liberty
PostPosted: Sat Feb 23, 2008 11:47 am    Post subject: temp Reply with quote
i just got mine and my A/C fan is rigged to a switch and it works fine.
