lockright locker non C clip
quietstorm
PostPosted: Sun Feb 10, 2008 6:49 pm    Post subject: lockright locker non C clip Reply with quote
Bare with me here, I'm a former yota guy, now a JeeP transplant, so I'm still learing.
So I have a ZJ, and the stock rear axle is a Dana 35 correct?
I came across a posting on my local Craigslist titled "I have a Dana 35 lockright locker non C clip" for a Dana 35.
This should work for my jeep right?
Thanks,
PostPosted: Sun Feb 10, 2008 7:45 pm    Post subject: Reply with quote
ZJ's have the D35 w/C clip, that locker won't work for you.
quietstorm
PostPosted: Sun Feb 10, 2008 7:48 pm    Post subject: Reply with quote
Damn. Well, thanks for the info.
What type of locker do you prefer?
My jeep isn't my daily driver, but it does see some highway time, and I'm not going to be wheeling it extremely hard, but it will definately be wheeled.
I suppose first step should be TC swap b4 lockers huh?
PostPosted: Mon Feb 11, 2008 6:09 pm    Post subject: Reply with quote
the first step would be a rear axle swap . get rid of the dana 35 its junk .
quietstorm
PostPosted: Tue Feb 12, 2008 9:23 am    Post subject: Reply with quote
Really? Before swapping out the TC, which is ultimate junk?
What's a direct swap on the rear axle for these things?
PostPosted: Tue Feb 12, 2008 9:49 am    Post subject: Reply with quote
Personally, I would swap the t-case first! The rear end will be fine until you start getting into larger tire sizes, unless you already run bigger meats. Cool
quietstorm
PostPosted: Tue Feb 12, 2008 9:55 am    Post subject: Reply with quote
Nope, currently running 32x11.50's not enough room to tuck anything else without going to a long arm kit, which I don't have 3k for at this time. Very Happy
On the TC swap, what, if anything should I be aware of prior to starting the swap? Should be a direct swap correct?
PostPosted: Tue Feb 12, 2008 10:11 am    Post subject: Reply with quote
It's not a direct swap unless the donor t-case has been prepped by someone else or it comes from a V8.
quietstorm
PostPosted: Tue Feb 12, 2008 10:52 am    Post subject: Reply with quote
Hmmm...
Ok, so if I get the case out of anything other than another V-8, what needs to be "prepped" on it...
kaos
PostPosted: Tue Feb 12, 2008 11:53 am    Post subject: Reply with quote
AIUI, this is considered the definitive writeup: http://jeephorizons.com/tech/tcase.html
You can also search for "transfer case swap" using the search box at the bottom of the page. It will bring up various other threads, detailing the problems and successes of other people.
Regards,
Kári
quietstorm
PostPosted: Tue Feb 12, 2008 12:38 pm    Post subject: Reply with quote
Great write up!
Thanks for the info guys! Cool
