| Author |
Message |
samm95 Member
Posted: Mon Feb 25, 2008 1:00 pm Post subject: Help!! 93' YJ running horrible and stalls!! |
Ok, a few months ago my heater core started leaking intermittenly. Seeing I haven't been driving it regulary, I didn't change it out immediately, and when I would drive it I would make sure there was coolant in the system. Last week I had to drive it a couple of days and after driving about 5 miles and stopping for gas on my way to work, I noticed steam coming from my radiator. I checked it out and discovered my radiator was leaking around the top. I waited for it to cool, opened the cap and saw there was still coolant in the radiator and overflow. I topped it off and drove the 5 miles back home.... very slowly and easy! The same night, after checking fluids again, I started it up and drove it to reposition it in my driveway, to work on it... no problem, started and ran fine! That night I changed the radiator and heater core, filled it back up and tryed to start it. It starts up, perfect for about 3 seconds then immediately " boggs down" runs very rough and almost stalls out, but I always cut it off before it stalls. The check engine light also comes on right before it almost stalls. I'm going to check the codes tonight , but I can not for the life of me understand what I did to cause this by changing the radiator and heater core??? I realize it might be a blown head gasket, but why did it run ok when I repositioned it in the driveway??
Any thoughts would be greatly appreciated!!! |
| Back to top |
Brad The Best Member
Posted: Mon Feb 25, 2008 10:29 pm Post subject: |
| pull the spark plugs they will be clean if you have a head gasket leak , the exhaust will also smell sweet . |
| Back to top |
Sykopro Member
Posted: Thu Apr 29, 2010 11:57 am Post subject: |
Did you figure out what caused this problem seeing as I am now having a very similiar problem? _________________ When you're lying on your back, the only way to go is up! |
| Back to top |
