4.0L Runs Cold?
johnnykomac
PostPosted: Sat Mar 08, 2008 12:20 am    Post subject: 4.0L Runs Cold? Reply with quote
My 4.0L is running cold. The temp guage never reaches half way.
Also, I'm only getting 14.5MPG.
Whats going on?!?!
PostPosted: Sat Mar 08, 2008 6:46 am    Post subject: Reply with quote
What temp is it reading?
It sounds like a bad temp sensor. That would cause it to send the incorrect engine temp to the ECU, and the ECU would then run the engine rich in an attempt to bring the temp up. That would explain why the MPG's are so low.
hutchman
Captain Kirk
Captain Kirk
PostPosted: Sat Mar 08, 2008 9:03 am    Post subject: Reply with quote
Does the heater blow really hot air or has it cooled off?
If the heater doesn't get hot chances are you have a stuck themostat.........
Just another thought.
johnnykomac
PostPosted: Sat Mar 08, 2008 10:39 am    Post subject: Reply with quote
When I first bought the car the temp reading was at 210 or a little higher. I changed the oil, used some lucas oil stabilizer, and made sure the coolant bottle was filled. Now, it never gets above 150 which, sounds way to low.
Wheres the temp sensor located. I thought it might be a TPS or MAF sensor and thats what could be making it run so rich.
How should I narrow down which one it is?
PostPosted: Sat Mar 08, 2008 12:33 pm    Post subject: Reply with quote
If the gauge is reading 150 degrees, then that's what the ECU thinks it's running at...resulting in the rich condition. The sensor is located in the thermostat housing.
dodger889
PostPosted: Tue Mar 18, 2008 5:43 pm    Post subject: Reply with quote
Ok if you can put your hand on top of the radator and able to hold it there for a little while then it running cold if you put your hand on the radator and it's hot where your hand feels burned by just touching it then it's running about right...
TheBrat97
PostPosted: Sun Apr 20, 2008 5:06 pm    Post subject: Reply with quote
I'd have to agree with Phantum on this one. The temp sensor is inexpensive and easy to replace so it's worth a shot. Oh and don't forget to use teflon tape! Mr. Green
