clicking
bgreiwe
PostPosted: Fri Mar 14, 2008 1:24 pm    Post subject: clicking Reply with quote
Sorry, I guess I should be a little more detailed.
I have a 2001 TJ with a 2" OME lift and 31s
When I turn the wheel, there is a clicking sound. Somtimes it is worse than others and I can't really tell what side it comes form other than I know the frnt.
Thanks guys.
PostPosted: Sat Mar 15, 2008 10:14 am    Post subject: Reply with quote
What did you check? How did you check it? Is everything tight? Did you check it? Make sure everything is at proper torque spec. When you've gone that, tighten the front axle side trackbar mount some more.
TJRobbie00
PostPosted: Sat Mar 15, 2008 12:20 pm    Post subject: Reply with quote
this probly isnt the answer but are your tires rubbing? cuz you say its only when you turn
kizer
The Link Meister
The Link Meister
PostPosted: Mon Mar 17, 2008 2:54 pm    Post subject: Reply with quote
On the tires is it a thud, thud, thud sound?
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
Blue4.2
PostPosted: Mon Mar 17, 2008 4:45 pm    Post subject: Reply with quote
How are your tie rod ends...still ok?? I have one worn out, doesn't make a clicking sound but feel it in the steering wheel. When you look at it, it pops up and down.
FARMER
PostPosted: Thu Mar 20, 2008 7:10 am    Post subject: Reply with quote
When the CV / universal joints start to go out the make a clicking sound when you turn.
1STMARINE05
PostPosted: Mon Apr 14, 2008 2:23 pm    Post subject: DID YOU FIND OUT THE PROBLEM?? Reply with quote
MY 98 WRANGLER IS DOING THE SAME THING, JUST WONDERING IF YOU FIGURED IT OUT SO I CAN FIX IT BEFORE SOMETHING BIGGER GOES WRONG,
THANKS
ANDREW
