| Author |
Message |
jeepunit Member
Joined: 15 Nov 2006 Location: N. Vancuver, British Columbia, Canada
Posted: Mon Mar 17, 2008 6:40 pm Post subject: 4.5" vs. 6" lift for 98 xj |
| i was wondering if anyone has experience with 6 inch lifts that could tell me if i could get away with putting a rusty's 6" without sye and driveshaft for a barebones stalk 98 4.0 xj. im not sure if 4.5" would satisfy me, but it does seem to be the cheaper route. or do i need a sye and driveshaft for 4.5 anyway? |
| Back to top |
ThePhantum Pissed-Off Admin
Posted: Mon Mar 17, 2008 7:01 pm Post subject: |
| At 6" you will ned an SYE. At 4.5" you might be able to get away with a tcase drop and axle shims, but you will severely reduce the life of your ujoints. |
| Back to top |
jeepunit Member
Posted: Mon Mar 17, 2008 7:09 pm Post subject: |
| and my stock driveshaft should be alright with an sye? |
| Back to top |
berk9 Member
Posted: Mon Mar 17, 2008 10:00 pm Post subject: |
i had 6" lift in the rear of my jeep with a t-case drop and no shims and had no drive line problems at all. it all depends on you and your jeep cus all jeeps are different, and so are the leaf packs. _________________ front 9" arb chromos 4.56s warn hubs; rear 8.8 detroit and 4.56s; rustys crap long arms crossmember and coils; RE leafs; rusty boomerang and 2' block; oh and trimming gotta love that sawzall |
| Back to top |
1fox2go Member
Posted: Tue Mar 18, 2008 10:42 am Post subject: |
True, I had 4.5 and needed the tcase drop _________________ 96 Cherokee 7.5 inch TnT long arm Locked F/R, D44 rear, 4.56s, 35x12.50 Muds/36x12.50 TSLs
| Back to top |
whlstnd Member
Posted: Fri Mar 21, 2008 6:14 pm Post subject: |
im running 6.5" of lift with a tc drop and a 6* shim with no vibes or problems at all.
mike |
| Back to top |
