Brake light short
Choptop
PostPosted: Sat Mar 22, 2008 7:21 am    Post subject: Brake light short Reply with quote
When I have the headlights on and I step on the brakes the passenger side brake light does "not" come on, but there "is" a dim light that comes on both back-up lights. If the headlights are not on everything works fine. I have checked all connections and the wiring seems to be in very good condition. This is on a 200 Wrangler. Any ideas?
quadna71
PostPosted: Sat Mar 22, 2008 10:11 pm    Post subject: Reply with quote
that happened on my wife's tj - it was right after i had installed some rear tail-light guards. it turns out that i wasn't getting a good solid connection between the tail-light housing and the tub via the 3 mount bolts on th eleft side. i pulled them back out, cleaned up the metal where they grip on the tub, and reassembled. no problems since.
2003 TJ Sport
