1994 XJ Lazy Starter
The Jeepster
PostPosted: Mon Mar 31, 2008 8:00 am    Post subject: 1994 XJ Lazy Starter Reply with quote
Hi, great forum! I'm having a little problem with my 1994 Cherokee. She's a 4 litre High Output model and normally starts up with a roar - a really head turner, but after having a electrical short and a flat battery she now starts with a whimper , almost like it will stall. The engine turns over ok and once running and warm she's fine (we had an autogas conversion so she starts on petrol but runs on LPG, so it not this) Any ideas?
PostPosted: Mon Mar 31, 2008 7:37 pm    Post subject: Reply with quote
battery . how long was it dead for ? thats what kills a battery . being dead for a long time , you can kill one but you have to charge it .
The Jeepster
PostPosted: Tue Apr 01, 2008 2:53 am    Post subject: Reply with quote
The battery discharged overnight. The postive earth lead connection was loose (the end came off when I took the battery leads off). It's only when she starts up on petrol when cold that it sounds lame, starting up on LPG or starting warm it's fine.
jppilot61
PostPosted: Tue Apr 01, 2008 4:16 am    Post subject: Reply with quote
Are you describing a starting problem or a Cold engine Idling problem?
Unless you know it is clean, I'd start with Cleaning the Throttle body and make sure the TPS (Throttle Position) Sensor is working correctly and possibly even the IAC Valve (Idle Air Control). Sensors were about $40 each here in US.
Cleaning the Throttle Body of probably 15+ years of gunk and shellac-like substance and changing my TPS sensor allowed my JEEP to begin starting great as opposed to only every other time of cranking it.
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
DavidXJ
PostPosted: Tue Apr 01, 2008 6:50 am    Post subject: Reply with quote
Cherokees will often start lame after a discharged battery. I've had to jump them a few times after a dead battery, and they don't run well until they've been running a bit (might be because the computer needs to reset?). So if your battery has been dying, that could be your problem.
Toliver09
PostPosted: Tue Apr 01, 2008 12:38 pm    Post subject: Reply with quote
i think this is the same problem i am having. My battery had a dead cell and I had to replace it temporarily with a smaller battery (only 280 cca) It starts, sputters and dies twice and on the 3rd start it get right up. My check engine light also came on and I havent checked codes yet, but I'm sure it has something to do with the battery, I only run 12v on the gauge
The Jeepster
PostPosted: Wed Apr 02, 2008 10:18 am    Post subject: Reply with quote
[i].............Cherokees will often start lame after a discharged battery. I've had to jump them a few times after a dead battery, and they don't run well until they've been running a bit (might be because the computer needs to reset?). So if your battery has been dying, that could be your problem.[/i]
Thanks. Must have been. She's back to frightening the neighbours now. Heh heh. Finger
