transmission mounting skid plate
trailman
PostPosted: Thu Apr 16, 2009 4:11 pm    Post subject: transmission mounting skid plate Reply with quote
I have a 95 yj that came with 1.5" spacers between frame and skid plate. Since i have changed rear diff to 8.8 and installed a sye kit in transfercase i would like to know if there would be any problems with mounting skidplate flush against frame.
PostPosted: Thu Apr 16, 2009 6:31 pm    Post subject: Reply with quote
The only issue I can think of is driveshaft length. Do you already have one for the rear? It would be best to get one after the t-case drop kit is removed. How much lift are you running?
PostPosted: Fri Apr 17, 2009 6:22 am    Post subject: Reply with quote
Yes, you should be able to remove the t-case drop.
trailman
PostPosted: Fri Apr 17, 2009 6:53 am    Post subject: Reply with quote
has soa , and i will be buying a cv driveshaft for the rear after raising the plate back up thanks for your info
