gears ?
tt66240
PostPosted: Tue Apr 01, 2008 4:48 am    Post subject: gears ? Reply with quote
hey guys the tag on my front axle has 53005567
10 6103 19-4 can you tell me what i have and if its worth a crap cause i am havin trouble with my rear end so i am lookin for a rear off of a explorer so let me know
________
Honda ST series
jppilot61
PostPosted: Tue Apr 01, 2008 6:37 am    Post subject: Reply with quote
Stock YJ's came with a Dana 30 (27 Spline) in the front
http://www.naxja.org/forum/showthread.php?t=930446
http://www.rsgear.com/catalogs/Diff/Dana_Jeep_30_2.pdf
(Google makes even me look like I know stuff!!!!)
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
PostPosted: Tue Apr 01, 2008 7:31 am    Post subject: Reply with quote
Stock YJ's will have a D35 in the rear. I think that string of #'s is missing a number or two. Make sure is clearly readable and see if there are more. If not check the front tag. What engine and tranny do you have?
jppilot61
PostPosted: Tue Apr 01, 2008 8:00 am    Post subject: Reply with quote
I "assume" his FRONT tag reads:
53005567 10 610319-4
Dana 30
1990- 90 1/2 YJ Disconnect
4.10 gears
This from page 5 of the Table in 2nd link of my post (SPICER/DANA Parts list for 30)
You realize of course you must get same gears front and rear if you are swapping a Ford Axle right? If not the first time you put it in 4WD, you will not like the results! Something is going to break!
1992 XJ Laredo
tt66240
PostPosted: Tue Apr 01, 2008 8:11 am    Post subject: Reply with quote
i dont wanna fix it i wanna put the ford explirer rear on it swamp boy( he has been a great help) told me it would fit and i would have disc brakes and i have found one from a 1998 with forty thousand miles for three hundred that measures 45 1/2 " from back plate to back plate is that cool
________
When Rover Met BMW history
jppilot61
PostPosted: Tue Apr 01, 2008 8:29 am    Post subject: Reply with quote
Now I am confused. D30 on front. Info was from Front Diff tag.
Now you are talking REAR again. You MOST PROBABLY currently have a D35 on the rear and that is probably as weak an axle as you could possibly have. A FORD 8.8 would be a nice upgrade!
What gears are in the rear you are planning on swapping into it?
They will need to match the 4.10 you currently have in the front or you will need to regear front to match rear (or regear rear to match front) . . . .
They MUST match!
1992 XJ Laredo
tt66240
PostPosted: Tue Apr 01, 2008 8:51 am    Post subject: Reply with quote
yea man i know little about gears and stuff but it is the rear i want to change but the only numbers i could find were the ones i posted earlyer and they were off the front axels , and ive been told rear is crap so i want a ford one just wanted to know if you guys could tell me which ford rear to get as for as gears and if any year will work
________
Daihatsu Fellow Max
PostPosted: Wed Apr 02, 2008 12:20 am    Post subject: Reply with quote
http://jeephorizons.com/phpbb/viewtopic.php?t=3370
http://jeephorizons.com/phpbb/viewtopic.php?p=54980
As was mentioned, the gear ratio must match front and rear or you'll have major damage the first time you put it into 4wd.
PostPosted: Wed Apr 02, 2008 7:12 am    Post subject: Reply with quote
I deleted your other thread because it seemed to be the same thing you were asking here.
I'm still not sure what the hell you're asking but I'm gonna give this my best shot.
Your YJ has a D30 in the front and D35 in the rear. Being a 4-cyl, 5-speed, you should have 4.10 or 4.11 gears in them. These ratios are essentially the same. For simplicity, I will call them 4.10 for the remainder of my answer.
If you want to swap in an 8.8, you need to find one from a 95-02 Ford Explorer. Not a Mustang, not a Ranger, not an F-150. An Explorer or one of the other manifestations like a Mercury Mountaineer. They are available with 4.10s from the factory which would make matching your front axle (the D30) easy. However, being that you have a 4-cyl and you want to run heavy 33" tires, I would strongly recommend a better gear ratio. I'd go with 4.88, which also happens to be the lowest gear you can install in a D30 and is also available for the 8.8.
tt66240
PostPosted: Wed Apr 02, 2008 10:00 am    Post subject: Reply with quote
thank you you answered every thing and i know you guys must get aggravated with guys like me but if you guys ever have any questions on metalurgy be sure to ask and again thanks
________
glass pipes
tt66240
PostPosted: Wed Apr 02, 2008 11:52 am    Post subject: Reply with quote
well i have found a ford rear off a 2000 ford explorer wih 4:88 gears for 400 bucks and a rebuild kit from quadratec 170.00 for ring and pinion and 84.00 for bearing kit for front end is this sounding good to you guys
________
vapir no2
PostPosted: Thu Apr 03, 2008 12:51 am    Post subject: Reply with quote
It does but has that axle been regeared? That's not an OEM ratio.
tt66240
PostPosted: Thu Apr 03, 2008 4:37 am    Post subject: Reply with quote
never mind on 4:88 gears im stickin with the 4:10 so i dont have to mess with front at all if they dont turn ma 33's i will regear thanks guys
________
strain index
PostPosted: Thu Apr 03, 2008 7:21 am    Post subject: Reply with quote
It will turn them but you won't like the lack of performance.
redjeepr
PostPosted: Tue Sep 23, 2008 6:28 pm    Post subject: continued gear question... Reply with quote
I just picked up a D44 supposedly out of a 76 cherokee, I opened the diff and on the ring gear, just after the other string of numbers is "377" in larger font than the others.... does that mean the gears in it are 3.77?? It doesn't look like anyone has upgraded these axles, but I'm not good enough to know for sure.... Help
-RedJeepR
