1996 4.0 HO replaced head has no tapping for temp sensor
surfvan
PostPosted: Mon Apr 07, 2008 2:48 pm    Post subject: 1996 4.0 HO replaced head has no tapping for temp sensor Reply with quote
I have a 1996 cherokee sport replaced the head this weedend and found there is no tapping for the sending unit it is a single wire purple w/yellow tracer on the original head it was located in the rear right side of head how can I retro fit this to work? please help surfvan@aol.com thank you
TheRo0sTer
PostPosted: Mon Apr 07, 2008 3:15 pm    Post subject: Reply with quote
If you can drill straight and tap a hole you can do the fit. I had the same thing happen on a CA car when I pulled an exhaust manifold from a NV car. If the sensor requires a flat surface you might take it to a shop unless you have a counter bore set.
Cody82zxt
PostPosted: Mon Apr 07, 2008 8:38 pm    Post subject: Reply with quote
I had to do the same thing when I replaced my head. Just measure and drill and tap.
