weather window trim problem
Post new topic   Reply to topic     Forum Index -> Body & Paint
Usemy3rdArm
PostPosted: Thu Apr 10, 2008 10:44 am    Post subject: weather window trim problem Reply with quote
when i roll my window down that rubber felt gets turned inside and makes it very difficult to roll the window down, can you take it off? is it there for a reason? i know the outside part keeps the weather out but i see no purpose in the inside aside from looking pretty haha mines stapled to the plastic door cover, i cant bend it back wont bend back, anyone else have this problem?
PostPosted: Fri Apr 11, 2008 10:04 pm    Post subject: Reply with quote
The outside trim keeps water out during rainstorms, and the inside keeps pressure on the outside to make sure the window gaskets tight. I guess you COULD shave off some of the rubber on the inside and see if that solves your problem, but don't take off too much, or it won't keep water out properly.
Post new topic   Reply to topic     Forum Index -> Body & Paint All times are GMT - 8 Hours
