Switch from EFI to carb
My94YJ
PostPosted: Tue Apr 15, 2008 4:25 am    Post subject: Switch from EFI to carb Reply with quote
Something is frying my map sensor. I've replaced it a couple of times and it's starting to run bad again. I'm considering swapping the efi intake to a carbureted intake. Are there any changes that have to be made, as far as the computer goes, to make it run. Or can you swap them out and go? Also, with gas prices the way they are, would you recommend a 2 or 4 barrel? Will there much power or gas mileage difference? It's a 94 4.0.
Thanks!
