Injectors
PostPosted: Fri Apr 25, 2008 8:00 pm    Post subject: Reply with quote
Is the wire still plugged in?
mexirican
PostPosted: Fri Apr 25, 2008 9:36 pm    Post subject: Reply with quote
Which wire? All the wires that I disconnected were reconnected when I tightened things up today. Unless I missed one. What should I look for?
PostPosted: Sat Apr 26, 2008 7:41 am    Post subject: Reply with quote
The temp sensor has one wire attached. Here are two places it could be. If not there, look on or around the thermostat housing.
Rear right corner of the valve cover!
mexirican
PostPosted: Sat Apr 26, 2008 9:19 am    Post subject: Reply with quote
Would these usually just die? Before I dove into it, it was working fine. I never got close to it when I was working on it either. Is there a connector ontop of the engine somewhere? I unplugged a few connectors when I was removing the fuel rail. Would heat damage these sencors. My Jeep was just into the red before I was able to get off the freeway when everything took a dump on me.
PostPosted: Sun Apr 27, 2008 1:44 pm    Post subject: Reply with quote
its a notorious bad connection , wiggle it and watch the gage actually work , or get a new sensor it just senses resistance to ground , they corrode and become worthless once in a while .
thing happen for no reason , don't worry .
mexirican
PostPosted: Sun Apr 27, 2008 7:28 pm    Post subject: Reply with quote
Is there a connection on the top f the engine? I unplugged a few of the connectors when I was replacing the injectors. I wiggled the connectors on the sensor and the gauge is still reads zero.
mexirican
PostPosted: Tue Apr 29, 2008 3:52 pm    Post subject: Reply with quote
jppilot61,
I saw in an old post that you trimmed your front fenders. i was wondering if you had any more pictures of your job. i was planning on doing the same thing.
Thanks for the help again.
Toliver09
PostPosted: Sun May 04, 2008 7:09 pm    Post subject: Reply with quote
on my 92 the temp sensor is on the front driver side of the block right next to the thermostat housing and the temp SENDER for the gauge is on the rear top of the motor on the driver side, make sure you have the sender reconnected.
mexirican
PostPosted: Sun May 04, 2008 9:41 pm    Post subject: Reply with quote
Toliver09, Which engine do you have? My Cherokee has the I-6.
kaos
PostPosted: Mon May 05, 2008 1:45 am    Post subject: Reply with quote
I've just been having some temp gauge problems myself, and finally located the sender where Tolliver describes it. It is very easy to overlook, at least on the ZJ (haven't checked the XJ) as it is hidden behind a wiring bundle that runs alongside the valve cover. Anyway, that's where I found it; on top of the head, beside the valve cover on the drivers side, at the rear of the engine. The sensor on the thermostat housing is for the ECU. Oh, and it's the 4.0L.
Regards,
Kári
mexirican
PostPosted: Mon May 05, 2008 7:19 am    Post subject: Reply with quote
Unless I'm missing something, I don't see what you guys see. I have nothing connected to my thermostat. Just my upper radiator hose.
PostPosted: Mon May 05, 2008 8:11 am    Post subject: Reply with quote
Regards,
Kári
The pictures I posted, are of this location!
mexirican
PostPosted: Mon May 05, 2008 8:29 am    Post subject: Reply with quote
Ok. Lets get this straight. Are we talking about the sensor itself, or the connector? Orandeamc13, I found the sensor with the pix you sent. They worked great. THX!!! kaos, you are refering to the connectors on top of the engine, right? I am in the proccess of uplaoding some pix for you guys to make it idiot proof for me.
mexirican
PostPosted: Mon May 05, 2008 8:56 am    Post subject: Reply with quote
Ok. Here are the piks.
These are the two connectors that i disconnected when I took out my fuel rail...
This little connector is the only thing that i didn't connect. I forgot if it wasn't connected when I dove into it or if it was, and I just forgot were it goes. Rolling Eyes
Any help you guys have would be awesome.
kaos
PostPosted: Mon May 05, 2008 1:53 pm    Post subject: Reply with quote
Bingo! Very Happy
Look behind the wire bundle that is coming down from the firewall. The sensor should be lurking there on the corner of the head.
Regards,
Kári.
Page 2 of 3
